leaking tail lights
Old Mar 31, 2015 | 04:36 PM
rosqoe's Avatar
Default leaking tail lights
my tail light on my 2000 pace car have alot of condensation anyone repaired these or is it easier just to buy new ones
Old Mar 31, 2015 | 05:15 PM
owens91's Avatar
i havent seen anyone fix these but im not sure if it is even possible, might be better off getting some new ones
Old Mar 31, 2015 | 08:43 PM
tweek's Avatar
I would buy new ones or pull some from a salvage yard
Old Mar 31, 2015 | 11:11 PM
Many time the condensation gets in from the bulb openings. Typically one removes all the bulbs then thoroughly dries out their housing, with a hair dryer, sun etc. When you reinstall your bulbs use die-electric grease at all their bases and such to create a new vapor impervious seal which in turn should not let any more moisture enter the tail light housing.
Inspect the housings for any obvious cracks / seams coming apart and use a black silicone to seal these areas.
Old Apr 1, 2015 | 10:01 AM
03SSLE's Avatar
As Zippy mentioned, condensation can enter through the light openings. I replaced my washers with new ones and applied dielectric grease to both sides of them. I still got a small amount of condensation while washing the car so I drilled 3/16" holes in the bottom of the light housings and that resolved the problem.
Old Apr 1, 2015 | 12:00 PM
JC Colon's Avatar
I agree with everyone, sealing the light opening will stop the moisture from getting in. You could also drill a small hole or 2 in the bottom of the tail light housing. This combined with the heat from the bulbs will evaporate the moisture and give it a way to excape. This is a good fix but it could also decrease the life of your bulbs a bit!
rg9johns
Aug 22, 2014 10:46 PM
TKG2000
Nov 28, 2011 02:03 PM
01LS Goin Bad
Oct 28, 2011 12:48 AM
RickAKATed10
Jan 23, 2009 10:38 AM
