Lambo Doors - Are they worth it?
Although, if you do go with it, you'll be glad you spent the money for the high dollar kits, if not there's a very good chance after 1 or 2 times that door will be coming down on you when you get in and out.
Door fell on me 1 time and since then I check the door gap for hydralic fluid or whatever is in the shocks. Made a hissing sound and fell slowly but when it goes, the inside of the door will have fluid on it so I know now.
I don't get why everyone thinks the weld on kits would be better. These doors are bolted on from the factory. The quality of the hinges seems to me to be the deciding factor along with wiring management. I have NEVER seen anywhere that these aren't "street legal". The only place that you may have a problem with these would be at a racing event. In the event of a roll-over, you may not be able to escape your vehicle.
DRuben;
How did you solve your wiring management concerns? On my mother's Suburban, there are plates and pins that completely lose contact when the doors are open. Then, when the doors close, they make contact again. Would a set-up like that work with your door style?
DRuben;
lol. When I got the car the wires were electrical taped (I know
) together and always came apart. I removed it all and extended all the wires about 4 inches and heat wrapped them. My next project is to lengthen the wires so the connecting harness is inside the car and have the wires in a wire cover thingy. As of now the harness is hanging on the hinge.
DRuben;
