7th Gen ('06-'07): keyless entry
Not sure if this thread goes here but I have a question
Ok my key less entry system is acting weird.
Open door key fob works new batteries in both and new battery in car 3 months old.
Not sure what to look up to find if there is some thing is loose but not sure where to look I have checked all the usual places if there is a messed up wire and blown fuse.
most of the things are no longer made for a 12 year old car. mainly the interior and stock rims for it as well as some electrical other than the most common things that break for now.
exept the key less entry module where every where said it is not a option even though our cars came with the basic as well as the auto start option on some models
i am drawing a blank on where to look next as well as wanting to pull my hair
Are you just having issues unlocking the car from a distance with the FOB?
If so, it's not you, it's the car. There was a TSB about the range on them, and the whole module needs to be replaced. But it's not a safety issue, so it was never a recall, and you aren't under warranty anymore, so it's all out of pocket.
http://ww2.justanswer.com/uploads/Ch...d__2334176.pdf
its not from a distance it is like it stops working till I open the door then the fob works then stops working also hitting the unlock button is finiky as well. it is frustraiting to be honest chibi. not just that it is a little frustrating to be honest. if it is not one electrical issue fixed it is another. love the car because I get amazing mpg out of it. as well it runs great for the most part. have to change the pan gasket because it is leaking it didn't get put on right when I got the pan dropped and filter changed. plus trans mount broke. I noticed that when I changed out the dog bones as well as the mounts they go on at the radiator. granted at least I know what it needs and go from there. thank you for your help chibi
