Help with spoiler!
Old Dec 29, 2014 | 07:20 PM
Red Monte Carlo's Avatar
Question Help with spoiler!
Ok, so i painted my spoiler today with a few coats, and then i put a few clear coats on it. It looks great just like my old one! When i put them both side by side they were the same color and everything, but my old one seemed much smoother and when I ran my fingers on them both, my new one felt rougher than my old one. Does anyone know how I could make my new spoiler as smooth as my old one? here are some photos below of my old one compared with my new one. Btw, the new one is still not dry so it looks a lot shinier right now.
Old Dec 29, 2014 | 07:22 PM
And here is the old one
Old Dec 29, 2014 | 08:37 PM
I believe you need to let the clear coat completely dry and then wet sand it with a very, very , very fine grit sand paper.
Hopefully someone with more experience can chime in with better details.
Old Dec 29, 2014 | 08:59 PM
ohara's Avatar
+1
it is in the fine detail work, you need to get lighter grit sandpaper and wet sand the clear coat, and then buff it, it should shine up nicely when done
Old Dec 30, 2014 | 08:29 AM
You need to wet sand it with some 800 or 1000 grit sand paper,
Then buff it . Just sand it til its smooth..don't over sand it or it will go thru the clear cote finish.
When we repainted mine... We did 4 coats of clear...That way we got a nice high gloss shine after wet sanding and buffing!
Old Dec 30, 2014 | 09:59 AM
MAMONTE's Avatar
I agree, wet sand with 1000 grit paper...then get some clear coat safe rubbing compound, rub it out, then polishing compound.
Old Dec 30, 2014 | 11:00 AM
I just woke up this morning and its much dryer and smoother. It looks just like the other one, except its not a shiny and glossy. Would i need to apply more clear coat? Ive already used 2 cans completely on it and about 5 coats I think.
Old Dec 30, 2014 | 11:22 AM
farmerjg's Avatar
Did you see that four people told you to wet sand? What you want is what they all recommended you do.
Old Dec 30, 2014 | 03:11 PM
I had my uncle come and look at it and he said NOT to wet sand it since the clear coat came out of a can and its fresh and since I have never did anything like that I would probably sand it all off. Its already smoothed out a lot overnight so I should apply more clear coat since I did the clear coat wrong the first time Im going to put more on it at a closer distance and he said it should shine more like the other one.
Old Dec 30, 2014 | 11:06 PM
Enzo354's Avatar
STILL SLOW
Yea man, listen to your uncle. He knows. Make sure you let the paint cure for at least 3 months before you let it go outside into the cold or it will make it peel.
