Help with spoiler!
1 Attachment(s)
Ok, so i painted my spoiler today with a few coats, and then i put a few clear coats on it. It looks great just like my old one! When i put them both side by side they were the same color and everything, but my old one seemed much smoother and when I ran my fingers on them both, my new one felt rougher than my old one. Does anyone know how I could make my new spoiler as smooth as my old one? :confused: here are some photos below of my old one compared with my new one. Btw, the new one is still not dry so it looks a lot shinier right now.
1 Attachment(s)
And here is the old one
I believe you need to let the clear coat completely dry and then wet sand it with a very, very , very fine grit sand paper.
Hopefully someone with more experience can chime in with better details. |
(Post 641650)
Hopefully someone with more experience can chime in with better details. it is in the fine detail work, you need to get lighter grit sandpaper and wet sand the clear coat, and then buff it, it should shine up nicely when done |
You need to wet sand it with some 800 or 1000 grit sand paper,
Then buff it :thumbsup:. Just sand it til its smooth..don't over sand it or it will go thru the clear cote finish. When we repainted mine... We did 4 coats of clear...That way we got a nice high gloss shine after wet sanding and buffing!:) |
I agree, wet sand with 1000 grit paper...then get some clear coat safe rubbing compound, rub it out, then polishing compound.
I just woke up this morning and its much dryer and smoother. It looks just like the other one, except its not a shiny and glossy. Would i need to apply more clear coat? Ive already used 2 cans completely on it and about 5 coats I think.
Originally Posted by Red Monte Carlo
(Post 641737)
Originally Posted by farmerjg
(Post 641741)
Did you see that four people told you to wet sand? What you want is what they all recommended you do.
Yea man, listen to your uncle. He knows. Make sure you let the paint cure for at least 3 months before you let it go outside into the cold or it will make it peel.
