Bolts??
Old Feb 17, 2011 | 02:16 PM
monte003's Avatar
Default Bolts??
Does anyone know where the bolts are to tighten up the front and back bumper mine has seem to come lose thanks
Old Feb 17, 2011 | 05:42 PM
20112010200920082007200620052004200320022001200019 99199819971996199519941993199219911990Classic Vehicles Make: (Select Make)BuickCadillacChevrolet/GeoGMCHummerOldsmobilePontiacModel:(Select Model)AstroAvalancheBlazerCavalierCorvette ConvertibleCorvette CoupeExpressImpalaMalibuMonte CarloS-10Silverado 1500Silverado 1500HDSilverado 2500Silverado 2500HDSilverado 3500SSRSuburbanTahoeTrackerTrailBlazerVenture 2003 Chevrolet/Geo Monte Carlo Air conditioner and heater Alternator Automatic transaxle Back glass Body hardware Brakes Console Cooling Cooling system Cowl Door Electrical Emission system Engine Engine / transaxle Exhaust system Fender Front bumper Bumper and components Bracket Bumper cover Ls Nut Reinforcement Retainer Ss Center support Emblem Energy absorber Extension Filler cover Impact bar Lower support Tie down Upper support Front drive axle Front lamps Front suspension Fuel system Hood Hvac Information labels Instrument panel Maintenance & lubrication Pillars rocker and floor Quarter panel Radiator support Rear body and floor Rear bumper Rear lamps Rear suspension Restraint systems Roof Seats and tracks Starter Steering Steering column Steering gear and linkage Steering wheel Stripe tape Trunk lid Wheels Windshield
Part Number Search
Multiple Part Number Search
All OEM Special's
Classic Vehicle's
Show All Parts Mechanical Parts Only Body Parts Only Please select a corresponding number from the illustration below to view the details of that part.1) Bumper cover Ls2) Retainer Upper3) Retainer Lower4) Retainer Outer5) Bumper cover Nut6) Reinforcement Reinforcement Back7) Energy absorber8) Energy absorber Retainer9) Upper support10) Upper support Nut11) Lower support12) Lower support Retainer13) Center support14) Impact bar15) Energy absorber Energy absorber Right16) Bracket Bolt17) Tie down18) Extension Ss high sport19) Filler cover License plate20) EmblemDescriptionYearMSRP PriceYour PriceFASCIA
00-05 $468.17$287.27
Heres a break down of front bumper, you can look up rear break down gmpartsdirect.
Old Feb 17, 2011 | 06:35 PM
mrl390's Avatar
You will have to move the splash liner to get to them. There are studs that stick down from the fenders and the quarter panels that the bumper covers slide up over. Then there are 10mm nuts that fasten them together. If you look up in the wheel well you should be able to see them.
Old Feb 18, 2011 | 02:52 PM
monte003's Avatar
is anyone has auctual picture that would help a ton
Crazy4408pac
Feb 19, 2011 12:18 PM
LW57912
Mar 27, 2010 08:49 PM
nitehawkjcb
Jan 6, 2010 01:46 AM
turbo895
Jul 15, 2008 01:33 AM
montecarlomike81
Feb 22, 2008 08:28 PM
