6th Gen ('00-'05): 03 Monte LS - Clone SS?
Hello,
I have a 03 Monte LS and I need a new front bumper. I'm wondering if their is any difference between the LS Bumper and SS Bumper? I want to put fog lights in it also. What parts interchange from the SS to the LS also?
Thanks!
Thanks!
The 00-05 ls and ss bumper covers are the same. The only difference is if you get the added high sport ground fx (to install the his ground fx require cutting slots in the front bumper cover).
My SS is one of the cloth interior ones.
Also, the 00-04 SS came with a L36 non-supercharged 3800 v6. The '05 SS was a L67 Supercharged 3800. '06-'07 the SS was a v8.
Hi Bkoso85,
As far as the fog lights go, it is fairly easy to find fog lights and a fog light switch at a parts interchange or junk yard and you will be able to mount them to the inside of any stock bumper cover w/o issue(that's what I originally did on my ls). Next, all you need to do is to run a line to the fog light housings from the fog light switch, and then get a power feed from the fuse panel (preferably the fuse block dedicated to the external lighting) to the switch. The correct way to do it would be to swap harnesses, but if you are on a budget and have a basic knowledge of wiring(or know someone who does), this is an effective way to get fog lights.
