Word of Warning!!!
Good afternoon everyone... I've attached a picture of my interior, in particular the racing pedal set-up... Here is what happened to me yesterday... I put some low profile winter matts in and didn't bother to check the clearance of the raised lip and the accelerator pedal travel... I was driving in the city about 60km/hr and when I let my foot off the gas the pedal stuck at 4000 rpm (I was going slow, but accellerating quickly)... I had trouble applying brute force to the brakes and finally had to switch off the engine during braking (the power assist brakes get very heavy quickly)... I managed to stop the car safely, but still had no idea what was wrong, I started it again and it was revving at 4000rpm... I quickly figured out what was wrong and corrected (the mat had pushed forward)... My main point here is, if my 17yr old son or wife were driving, it might have ended badly... I've had muscle cars most of my life, and have done some crazy things with them including a broken throtle spring on my GTO while doing donuts in the snow, needless to say, nothing like this has ever happenned... Word to the wise, it can and did... Thanks,
That's the reason why I threw away those thin Chevy-autzone mats.
They're aren't heavy enough to stay in place so they would slide under the pedals and i was concerned something like that would happen when my wife or I would drive it.
I threw them away and kept the carpet mats instead, alot heavier and safer.
Glad you're alright.
Next time pop it into Neutral and then apply the brakes. Only applying the brakes will not be as effective as braking while in neutral. Thats why all those Toyota crashes happened, because their drivers didnt have the sense to put the car into neutral.
Last winter I bought a set of Michelin rubber mats from Costco. These are super heavy winter mats and have the channels to help keep the water away from your pants. I made sure they fit properly around the gas pedal. Love `em. They didn't slide around on me. And I only had to shampoo the little strip of carpet between the sill and the rubber mat.
I'm glad everything came out okay. Thanks for the warning. This is not just a heads up on floor mats. It's also a heads up on the aftermarket "dress-up" pedals too.
I wanted to transfer the bolt on pedals I had on my Grand Am. Only to find that they wouldn't fit properly. I hated that I wasn't able to put on the fancy black & red pedals since the factory pedals are kinda boring and ugly. But I suppose I would look kinda ugly after crashing into a tree or something because of my ill-fitting aftermarket pedals.
Thanks for the heads-up Crusader! Way to go on the quick thinking!
