Who has over 120k miles on their m/c
Old Dec 10, 2011 | 11:58 AM
  #31
seawolf18's Avatar
I have 155K miles on mine. I drive it about 80 miles a day to work. So far its been a pretty reliable car. I have had a few problems with mine. I had to replace the intake gaskets, front brakes, both coolant elbows, and valve cover gaskets. The transmission is now starting to give me problems when its cold, but come out of it when it warms up. I suppose that will be the next thing that will need to be replaced on it.
Old Dec 11, 2011 | 05:15 PM
  #32
RocknSS04's Avatar
156K on the Intimidator SS. I bought it with less than 5K on the odometer in show room condition from a FxxD dealer in PA on Ebay for half price. Had it shipped here. Still saved about $5K on it.
Other than brakes and tires, the only real problem I've had has been breaking flex plates. I'm on my 4th or 5th on now. Really don't remember. I twisted the center out of the 2nd one (NOT stock anymore!). I've gotten good at pulling the tranny. I think I have a strut mount going bad right now, but I'm not sure.
And I'm about ready to replace the brake rotors and pads. But the rotors are Powerslots, and I had them on my '01 SS LE before this car. They had 35K on them when they were exchanged with the factory brakes on this car, so they have over 190K on the rotors! I MIGHT be able to turn them one more time. I'm going to try.
That's still not bad for a car that is now driven primarily in the Michigan winters. That's right, this is my winter beater.
Old Dec 11, 2011 | 07:32 PM
  #33
BlackRainSS's Avatar
Wow PacerSS thats one of the most beautiful 208k Montes I've ever seen
Old Dec 21, 2011 | 12:49 AM
  #34
2003L67SS's Avatar
just over 178,000 here had it since 10K, 3rd motor 2 na this one's S/C, 5th trans, and 4th flexplate, runs strong now with a built trans, fixed the drivetrain and now my stereo blew and idk why i beat on it for 3 years and 3 JL speakers went in the past month, new pioneer components ordered
PacerSS where did you get that hood made???? i thought about making one exactly like that but i didn't know if it would look good or not
and i'll have this car in one form or another til' the day i die.
Old Dec 21, 2011 | 02:53 PM
  #35
rj's Avatar
rj
The '81 SC is right at $150,000 miles.
The '86 LS is at 212,xxx miles. Second engine. In 1997 my girlfriend was out smoking the back tires one friday night while I went with a buddy to look at a '55 Chevy 2-door Wagon.
When I got home I hear, "There something wrong with YOUR car."
(why is it always mine when something goes wrong?)
Local transmission shop said the torque converter splines were stripped out. They were able to save the 200-4R trans. But they still charged me $700 for the work.
Old Dec 21, 2011 | 04:14 PM
  #36
Cowboy6622's Avatar
You can add valve cover gaskets , serpentine belt, and coolant elbows to my list.
Personally, I think running the heater hoses through the atlernator bracket is one of the most **** poor designs I have ever seen.
So I guess that makes it...
Everything the previous owner did (nothing major to my knowledge, know he had the transmission flushed at 50,000 miles though)
Two sets of tires + Factory set
A/C replaced in April '07.
Warped brake rotors in March '08. Run Akebono street performance pads. The current rotors are starting to warp some.
Spark plugs and wires replaced in August '08
New battery in February '09
Tires in August '10
Transmission flush in October '11
Valve Cover Gaskets, heater hose elbows, and serpentine belt in December '11
Old Dec 21, 2011 | 05:10 PM
  #37
I think given how that engine was designed, it's tough to get around any design for the heater hoses that is not somewhat "goofy".
My big question..... Those plastic elbows fail so frequently, why is there not a better after market solution? Like a solid elbow (maybe stainless)?
At least they are CHEAP and readily available at the parts store.
Old Dec 21, 2011 | 05:31 PM
  #38
Cowboy6622's Avatar
Mine didn't fail until I snatched the alternator bracket off. I think they fail when they're moved, not just on their own. Basically, hwen you change valve cover gaskets, they screw up.
Old Dec 21, 2011 | 05:50 PM
  #39
DRuben's Avatar
Im currently at 152,xxx
Old Dec 23, 2011 | 10:44 PM
  #40
2003L67SS's Avatar
my heater core plugged up and the top elbow somehow bent and pushed out without breaking... i was like wtf these have breaking problems and mine bent but didn't break, i was able to shove it back in and top it off with coolant and drive home to change the elbows
and someone mentioned the alternator support bracket being in the way of the HC hoses, I've had no issues running without the bracket, the alternator has enough support it wont budge
