Where Should i put my fog lights
Mine runs through a switch and is powered through a wire i tapped into thats on with the key. I run the fogs as drl's so they're always on. And being that they're LED i wasn't that concerned with the power they draw. But for wiring i'd reccomend doing something the guys said above, not what i did
You should jump the car from the battery itself, anything else and you risk melting wiring.
I would do it directly from the battery itself honestly. If that's not possible run it off the fuse box, but make sure you put in an inline fuse. You could also run it from the AUX fuse in the door fuse panels if needed, but you'd still have to run the wires to the fog lights.
Good point on the fuse though.. Make sure you install a fuse inline and as close to the battery as possible if the fog light kit did not come with one.
rg9johns
08-22-2014 10:46 PM
dc1
11-09-2013 01:48 AM
cornerview
16
08-18-2013 03:30 PM
siouxcity04montess
06-05-2010 05:49 PM
