low wiper fluid pressure
Old Sep 30, 2012 | 07:36 PM
tps221's Avatar
Default low wiper fluid pressure
can only really squirt right on the highway now anything i should look for to fix it my wiper blades also need to be changed they have started getting streaky after a little over a year best brand to replace with would be what?
Old Sep 30, 2012 | 08:07 PM
Actually:
Im considering trying the new ones by RainX...(wiper blades)
Try useing some minimal air pressure to blow the lines clear...
and check the connections of the lines at the pump for corrosion......
Old Sep 30, 2012 | 08:10 PM
Check the hoses for cracks or holes. Also it could be a bad o ring in the pump. As for the blades, I bought some Michelin's that were fairly cheap and work good.
Old Sep 30, 2012 | 08:12 PM
tps221's Avatar
somewhere its been leaking fluid since spring too i though it was just a leak in the tank could it be a hose?
Old Sep 30, 2012 | 08:19 PM
Yes it could be...besides the hose at your local auto parts is more than likely pretty cheap...
Old Sep 30, 2012 | 08:26 PM
tps221's Avatar
could i replace it in my college parking lot or do i have to do it around thanksgiving
Old Sep 30, 2012 | 08:28 PM
Id say you could do that anywhere...its as easy as pulling a tissue paper out of its box...
Old Sep 30, 2012 | 08:41 PM
tps221's Avatar
my dad is suggesting i leave it home for a week to have that fixed possibly the cat and maybe the fuel pump the gauge is acting alittle funky
Monteimpala
Mar 8, 2012 02:32 PM
StrongTakeover
Jan 25, 2012 02:36 PM
silver1
Jan 28, 2010 08:04 PM
1984LCMonte
Aug 18, 2009 02:59 AM
vita
Mar 29, 2009 12:24 PM
