low wiper fluid pressure
can only really squirt right on the highway now anything i should look for to fix it my wiper blades also need to be changed they have started getting streaky after a little over a year best brand to replace with would be what?
Actually:
Im considering trying the new ones by RainX...(wiper blades) Try useing some minimal air pressure to blow the lines clear... and check the connections of the lines at the pump for corrosion...... |
Check the hoses for cracks or holes. Also it could be a bad o ring in the pump. As for the blades, I bought some Michelin's that were fairly cheap and work good.
somewhere its been leaking fluid since spring too i though it was just a leak in the tank could it be a hose?
Originally Posted by tps221
(Post 498539)
could i replace it in my college parking lot or do i have to do it around thanksgiving
(Post 498543)
my dad is suggesting i leave it home for a week to have that fixed possibly the cat and maybe the fuel pump the gauge is acting alittle funky
