Little help on the intrigue
Old Oct 4, 2011 | 04:07 PM
Budsjlm's Avatar
Default Little help on the intrigue
Been having some flickering of headlight, dash light ect, bat cables/terminals are clean and tight
took 2 vids it just barely does it in the first vid right at the begining, and none that i can tell in the second, i'll try to get good video of it soon
i just find it wierd becuase it seems to be all lights dim not just one or 2, and there is no effect in performance,
yeah i know i need gas, also have a ses due to bad gas cap...
Old Oct 5, 2011 | 07:22 AM
03SSLE's Avatar
I just did a quick search on the problem, and from what I gather it is due to the alternator. Some say it is the initial amperage draw of the smog pump turning on and others say it is a malfunctioning voltage regulator. In either case the solution was to replace the alternator. It is suggested to NOT get the Delphi (same problem all over again) and get a Bosch instead. One person also mentioned their alternator wiring harness had worn insulation and to check it closely.
Budsjlm
Jan 29, 2012 06:58 PM
God_Bot
May 7, 2008 06:42 PM
ExplosiveSoundz
Mar 5, 2008 06:00 PM
cj702
Mar 3, 2006 02:31 AM
Cobramen
Mar 9, 2005 09:29 PM
