How not to do an oil change
Still, that being said, if he put 4 quarts in without draining he was either 3-4 quarts low prior, which is mind blowing, or he over filled it.
This is EXACTLY why I leave the oil changes to my mechanic. Their shop changes the oil and filter, checks and fills all fluids, checks tires and rotates if needed, plus helps with any other minor repairs I need between oil changes. And if the oil gets low between changes or the tires need a little more air, all I have to do is pull in and they'll fix it. It's worth way more than the charge for routine oil change ($24.00)!!!
TMoney
08-18-2013 02:37 PM
mstrmysterious63
09-25-2012 03:04 PM
dcnaser
03-25-2012 07:40 PM
70monte1
25
01-19-2010 09:04 PM
