abs light on...
Old May 12, 2013 | 11:13 PM
la oldie's Avatar
Default abs light on...
Well i have had the abs light on the car since i got it.. Its a 01 chevy monte catlo 3.4 this os the code it shows wondering if anyone else has gone threw this so i can get some help....
Old May 13, 2013 | 06:11 AM
I can try and look it up in the shop book tonight. Maybe post the diagnostic chart.... But I've never seen that one...
Old May 13, 2013 | 06:41 AM
03SSLE's Avatar
Try cleaning the ground connection for the ABS module. If that doesn't resolve the problem the pump motor may have shorted out and needs replacing.
Old May 14, 2013 | 07:11 AM
la oldie's Avatar
Ok i will try that out thanks... But any idea where the ground is at?
Old May 14, 2013 | 09:15 AM
Red Nightmare's Avatar
i actually got that code after I changed a hub assembly & it just went away..
Old May 14, 2013 | 08:40 PM
la oldie's Avatar
I changed my hub already put a timken hub assembly in but lights stoll on i tried to.clear it but just pops up again...
Old May 14, 2013 | 10:07 PM
I lean back on what 03SSLE mentioned. I can get the troubleshooting guide for this error code (sorry I forgot to do it when I mentioned, I can try to pull it tomorrow).
Old May 15, 2013 | 05:19 AM
I hope this helps (the troubleshooting info from the shop book):
DTC C1218
Circuit Description
The system relay is energized when the ignition is ON. The system relay supplies voltage to the solenoid valves and the pump motor. This voltage is referred to as the system voltage.
The electronic brake control module (EBCM) controls each solenoid valve by grounding the solenoid.
The EBCM controls the pump motor by grounding the control circuit. The pump serves 2 purposes:
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">Transfers brake fluid from the brake calipers to the master cylinder reservoir during pressure decrease events.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">Transfers brake fluid from the master cylinder reservoir to the brake calipers during pressure increase events.</td></tr></tbody></table>
Conditions for Running the DTC
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The pump motor is commanded ON.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The system voltage is greater than 8 volts.</td></tr></tbody></table>
Conditions for Setting the DTC
One of the following conditions exists for 0.16 seconds:
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">With the commanded pump motor voltage less than the system voltage, the actual pump motor voltage is 3 volts less than the commanded voltage.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">With the commanded pump motor voltage greater than the system voltage, the actual pump motor voltage is less than 8 volts.</td></tr></tbody></table>
Action Taken When the DTC Sets
If equipped, the following actions occur:
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The EBCM disables the ABS/TCS for the duration of the ignition cycle.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The DRP does not function optimally.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The ABS indicator turns ON.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The Traction Off indicator turns ON.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The message center displays the Service Traction System message.</td></tr></tbody></table>
Conditions for Clearing the DTC
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The condition for the DTC is no longer present and the DTC is cleared with a scan tool.</td></tr></tbody></table>
<table border="0"><tbody><tr><td valign="top"> • </td><td valign="top">The electronic brake control module (EBCM) automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.</td></tr></tbody></table>
Diagnostic Aids
The pump motor is integral to the BPMV. The pump motor is not serviceable.
Test Description
The number below refers to the step number on the diagnostic table.
  1. Tests the ability of the EBCM to control the pump motor. If the test lamp illuminates, the pump motor circuit within the EBCM is good.
<table border="1" width="95%"><tbody><tr> <th rowspan="1" align="center" valign="bottom">Step
</th><th rowspan="1" align="center" valign="bottom">Action
</th><th rowspan="1" align="center" valign="bottom">Yes
</th><th rowspan="1" align="center" valign="bottom">No
</th></tr> <tr> <td rowspan="1" colspan="4" align="left" valign="middle">Schematic Reference: Antilock Brake System Schematics
Connector End View Reference: Antilock Brake System Connector End Views
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">1
</td><td rowspan="1" align="left" valign="top">Did you perform the ABS Diagnostic System Check?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 2
</td><td rowspan="1" align="center" valign="bottom">Go to Diagnostic System Check - ABS
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">2
  1. Use the scan tool in order to clear the DTCs.
  2. With the scan tool, perform the Automated Test.
Does the DTC reset?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 3
</td><td rowspan="1" align="center" valign="bottom">Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">3
  1. Turn the ignition OFF.
  2. Remove the EBCM from the BPMV. Refer to Electronic Brake Control Module Replacement .
  3. Inspect the EBCM to BPMV connector for conditions which could cause an intermittent, such as damage, corrosion, poor terminal contact, or presence of brake fluid.
Is connector OK and cavity free of brake fluid?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 5
</td><td rowspan="1" align="center" valign="bottom">Go to Step 4
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">4
  1. If connector corrosion or damage is evident, replace BPMV and/or EBCM as necessary.
  2. If brake fluid is present, replace both BPMV and EBCM. Refer to Brake Pressure Modulator Valve Replacement and Electronic Brake Control Module Replacement .
Did you complete the repair?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 9
</td><td rowspan="1" align="center" valign="bottom">--
</td></tr> <tr> <td rowspan="1" align="center" valign="middle"> 5
  1. Connect the EBCM harness to the EBCM with the BPMV still separated.
  2. Connect a test lamp between the pump motor circuits, internal EBCM side, using the J 35616 Connector Test Adapter Kit .
  3. Turn the ignition ON.
  4. With the scan tool, perform the Automated Bleed.
Does the test lamp illuminate?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 8
</td><td rowspan="1" align="center" valign="bottom">Go to Step 6
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">6
  1. Turn OFF the ignition.Important: Removing battery voltage or ground from the EBCM will result in the following conditions:
    <table border="0"><tbody><tr><td valign="top"></td><td valign="top">Loss of the TIM learned tire inflation configuration parameters in the EBCM</td></tr></tbody></table>
    <table border="0"><tbody><tr><td valign="top"></td><td valign="top">The EBCM sets DTC C1245</td></tr></tbody></table>
    When the diagnosis is complete, inspect the tire pressures and perform the TIM reset. Refer to Tire Pressure Monitor Procedure in Tire Pressure Monitoring.
  2. Disconnect the EBCM connector.
  3. Connect the J 39700 universal pinout box using the J 39700-99 cable adapter to the EBCM harness connector only.
  4. Test both ground circuits of the EBCM including the EBCM ground for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
</td><td rowspan="1" align="center" valign="bottom">Go to Step 7
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">7
</td><td rowspan="1" align="left" valign="top">Replace the EBCM. Refer to Electronic Brake Control Module Replacement .
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">8
</td><td rowspan="1" align="left" valign="top">Replace the BPMV. Refer to Brake Pressure Modulator Valve Replacement .
</td></tr> <tr> <td rowspan="1" align="center" valign="middle">9
Does the DTC reset?
</td><td rowspan="1" align="center" valign="bottom">System OK
hotrodharley
Nov 15, 2013 11:37 AM
smartin40
Feb 20, 2011 10:56 AM
thomasnchy
Jun 5, 2008 08:23 PM
khno.29
Aug 16, 2007 04:55 PM
Bob50th
Jan 7, 2006 09:46 AM
