2012 Aston Martin + New Coupe's 400HP +
Old Mar 15, 2012 | 07:24 AM
Smile 2012 Aston Martin + New Coupe's 400HP +
2012 Aston Martin Virage: First Drive
The Virage bridges the gap between two already potent Aston Martin sports cars, but can it best the competition? Maybe.
I'll take one in all BLACK.. Member's do you like
the Aston Martin ? They are on my dream list..
I really like the one below...
<CITE sizcache="63" sizset="122" itxtHarvested="0" itxtNodeId="568">By James Tate of MSN Autos</CITE>
Click to enlarge picture
Inspired by Aston Martin's limited-edition One-77 halo car, the Virage's face features an uncluttered design with sharpened lines and unique front wings.
The latest Aston Martin model, the Virage, sits smack dab in the middle of the "entry level" DB9 and high-performance DBS in the historic British marque's sports car lineup. Unsurprisingly, it perfectly halves both the price and power differences between those two models.
With an attention-getting V12 burble and smoothly sculpted bodywork, the modern Aston Martin bloodline is unmistakable in the Virage. But does it have enough to stand on its own amidst ever-evolving competition?
Bing: High-Performance Sports Cars <~ Click
Model Lineup
The Virage is available in two flavors: the standard coupe and the topless Virage Volante. Both feature a soulful V12 mounted onto a bonded aluminum structure and display classically svelte Aston Martin looks. A number of wheel options are available, all 20 inches in diameter and wrapped in low-profile rubber.
Aston Martin used experience gained from the V8 Vantage when creating the Virage Volante. Featuring a solidly mounted rear subframe and a highly stiffened chassis, Aston claims there was no compromise to the Virage's rigidity when removing the fixed roof for the convertible top.
Under the Hood
The powerplant in the Virage is a hand-built V12 engine, six liters in size and creating a stout 490 horsepower and 420 lb-ft of torque. Although torque peaks at a fairly lofty 5750 rpm, 85 percent of it is already available at just 1500 rpm, making for a flat and very usable torque curve.
The engine sends its power through a carbon-fiber prop shaft, mated exclusively to a 6-speed automatic transmission mounted in the rear for optimal weight distribution. Co-developed with the transmission experts at ZF, the Touchtronic 2 gearbox features column-mounted paddles for manual gear changes.
With this engine and transmission, the Virage is good for a zero-to-60-mph run of 4.6 seconds and a top speed of 186 mph. The front-mid placement of the engine, as well as the rear-mid placement of the transmission, help make for a perfect 50-50 weight distribution.
View Slideshow: Best Bang for the Buck: Horsepower <~ Click
Inner `Space
True to Aston Martin form, the Virage's interior is one of elegance and luxury, rather than the performance-oriented cockpits found in its similarly priced competition. Each cabin calls for large amounts of fine leather and requires 70 man-hours to create.
Inside, the Virage is comfortable and mostly well designed, featuring impressive fit and finish and attention to detail. Particularly noteworthy are the hand-stitched leather surfaces, tasteful aluminum accents and center console. Aston Martin's signature polished-glass buttons are also a welcome addition.
The standard 700-watt premium sound system produces crisp, punchy audio, albeit at the expense of hearing the Virage's magnificent exhaust tone. The pop-out, Garmin-designed GPS unit, however, feels tacked-on and confusing, and simply is not up to the standard of those offered by other manufacturers , particularly in this price range. There are some signs of possible cost-cutting in the form of cheap-feeling buttons, ***** and even fonts, which are made even more obvious by the juxtaposition of other beautifully crafted elements.
Try the new MSN Autos mobile app, available on multiple platforms.
Out of the Virage's exhaust pipes comes one of the best engine sounds on the market today.
On the Road
Aston Martin sent us to the Nevada desert to sample the new Virage. While the broken local roads turned out to be a tough fit for the high-power coupe, we were still able to experience the car fully and get a solid understanding of its personality.
The first thing we noticed was the rumble coming from the large, traditional V12 engine. In fact, it'd be impossible to not take notice of this simply incredible exhaust tone — loud, raw and angry, without a hint of annoying.
Once out on the road, the Virage displayed smooth manners and competent handling, although we would've liked a little more weight to the steering, particularly right on center. When pushed into hard corners, it gripped well and provided decent feedback, but its 2-ton weight was equally evident. Thankfully, the tremendous ceramic brakes did a fantastic job slowing the slightly hefty Virage over the broken asphalt. Despite all attempts, we were unable to get the large brakes to fade; they achieved consistent stopping performance and feel time after time.
Bing Images: Aston Martin Virage
The hand-built V12 may be fairly old-fashioned in design, but 490 horsepower is still 490 horsepower, and when coupled with such a wide torque curve, this kind of power makes for plenty of very usable speed. While it's obvious Aston Martin didn't intend for the Virage to be a track monster, it's still quite fast, with triple-digit speeds creeping up alarmingly fast and with nearly comical ease. Although smooth and peaceful when cruising, a quick dip into the Virage's accelerator will unleash an intoxicating mix of chest-pushing torque and sonic fury.
On the other hand, that raw, naturally aspirated power must be channeled through an unfortunately uninspiring automatic transmission. Sure, it produced smooth shifts and was well programmed to the car, with minimal gear-hunting annoyance. Admittedly, the V12's bountiful torque helps out here, and as traditional automatics go, this one is great. Still, with the standard in transmissions quickly becoming crisp-shifting, multiclutch gearboxes with seven or eight forward ratios, the six-speed in the Virage produced somewhat of an antiquated experience.
As enjoyable as our test drive was, we found ourselves wondering if the world has somehow moved on from cars like this. Five, maybe even 10 years ago, this car would've set the bar for the luxury GT class, but new breeding has since changed the game.
View Slideshow: Autos in a League of Their Own <~ Click
Right for You?
If you're considering purchasing a car like the Virage, then it's a fair bet that you've done your research and largely know what to expect. It's an impeccably made grand touring car that packs plenty of power, refinement and passion. Essentially, it's a tremendous option for eating up highway miles in style and comfort, but probably won't appeal to those looking for the latest in automotive technology and performance. In many ways, it's an old brute of a GT car, and while it does a great job at that, it's far from revolutionary.
With the price for the fixed-roof coupe starting at $209,995, make no mistake that you're paying for status and exclusivity, elegance and desirability. You aren't buying a weekend track toy. The Virage, while beautiful and fast, simply stands no chance against much of its competition in terms of sheer performance. At its price point, alternatives from Ferrari, Lamborghini and now even fellow British manufacturer McLaren, vastly outclass the Virage on the track. Thankfully, it's obvious that lap times and bleeding-edge technologies aren't the goal here. The goal that Aston did set, however, is expertly achieved: It's another gorgeous, competent GT car from England for buyers with a taste for refinement — nothing more, nothing less.
See: New Coupes With More Than 400 Horsepower <~ Click Here to view/EnJoy/Buy (LOL)
The 6.0-liter engine is made entirely by hand at Aston Martin's UK factory. Its stark black plenum distinguishes the Virage's potent powerplant from its V12 brethren.
Each sumptuous Virage interior takes the Aston Martin craftsmen 70 man-hours to meticulously stitch and assemble, and requires seven full hides of Scandinavian leather.
I love the Rims
Sitting within the Virage's large 20-inch wheels are equally massive carbon-ceramic matrix brakes, good for improved heat resistance, stopping power and progressive pedal feel.
Bi-xenon headlights, borrowed from the Rapide supersedan, artfully follow the smooth lines of the car's side, helping the Virage to appear machined from one solid piece of aluminum.
Old Mar 15, 2012 | 07:29 AM
SPONSORED
<INPUT value=14530 type=checkbox jQuery1331814463814="367">
2012 Chevrolet Corvette Add to favorites
Price (MSRP):
$49,600 - $121,600 N/A
Fuel economy:
14-16 mpg city / 21-26 mpg hwy
User rating:
NaN N/A
Sponsored By Chevrolet <IFRAME id=dapIfM1 height=1 src="javascript<b></b>:void(document.write('<html><head><title>Adverti sement</title></head><body id=&quot;dapIfM1&quot; leftmargin=&quot;0&quot; topmargin=&quot;0&quot; style=&quot;background-color:transparent&quot;><script type=&quot;text/javascript&quot;>var inDapIF=true; var inDapMgrIf=true;</script><script type=&quot;text/javascript&quot;>function startTimer(){if (event.srcElement.readyState == &quot;complete&quot {parent.verifyDapResize(1);window.setTimeout(&quot ;document.close();&quot;, 2000);}}</script><script type=&quot;text/javascript&quot; src=&quot;//a.rad.msn.com/ADSAdClient31.dll?GetSAd=&DPJS=4&PN=MSFT&ID=313D9E 5FC42A6AE82CBF9CD0C72A6A36&MUID=313D9E5FC42A6AE82C BF9CD0C72A6A36&PG=CP4DOB&AP=1402&quot; onreadystatechange=&quot;startTimer();&quot;></script></body></html>'));" frameBorder=0 width=1 allowTransparency scrolling=no></IFRAME>
More info
Show 21 available trims
SPONSORED
<INPUT value=14373 type=checkbox jQuery1331814463814="368">
2012 Ford Mustang Add to favorites
Price (MSRP):
$22,310 - $40,310 N/A
Fuel economy:
17-19 mpg city / 25-31 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
Show 3 available trims
SPONSORED
<INPUT value=14488 type=checkbox jQuery1331814463814="369">
2012 Chevrolet Camaro Add to favorites
Price (MSRP):
$23,280 - $54,095 N/A
Fuel economy:
14-19 mpg city / 19-30 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14592 type=checkbox jQuery1331814463814="370">
2012 Dodge Challenger Add to favorites
Price (MSRP):
$24,995 - $43,995 N/A
Fuel economy:
14-18 mpg city / 23-27 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
Show 1 available trims
SPONSORED
<INPUT value=14669 type=checkbox jQuery1331814463814="371">
2012 Mercedes-Benz C-Class Add to favorites
Price (MSRP):
$34,800 - $61,430 N/A
Fuel economy:
13-21 mpg city / 19-31 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14463 type=checkbox jQuery1331814463814="372">
2012 Cadillac CTS Add to favorites
Price (MSRP):
$35,915 - $63,215 N/A
Fuel economy:
12-18 mpg city / 18-27 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14366 type=checkbox jQuery1331814463814="373">
2012 Ford Shelby GT500 Add to favorites
Price (MSRP):
$48,810 - $53,810 N/A
Fuel economy:
15 mpg city / 23 mpg hwy
User rating:
9.8 N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14530 type=checkbox jQuery1331814463814="374">
Price (MSRP):
Fuel economy:
User rating:
NaN N/A
Sponsored by Brand
More info
Show 13 available trims
SPONSORED
<INPUT value=14609 type=checkbox jQuery1331814463814="375">
2012 Mercedes-Benz E-Class Add to favorites
Price (MSRP):
$49,800 - $91,500 N/A
Fuel economy:
15-21 mpg city / 23-32 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14841 type=checkbox jQuery1331814463814="376">
2012 BMW M3 Add to favorites
Price (MSRP):
$60,100 - $68,750 N/A
Fuel economy:
13-14 mpg city / 20 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
SPONSORED
<INPUT value=14500 type=checkbox jQuery1331814463814="377">
2012 BMW 6-Series Add to favorites
Price (MSRP):
$73,600 - $93,500 N/A
Fuel economy:
15-21 mpg city / 20-31 mpg hwy
User rating:
NaN N/A
Sponsored by Brand
More info
Show 2 available trims
Old Mar 15, 2012 | 07:43 AM
03SSLE's Avatar
Originally Posted by Space
If I were in the market for a vehicle of that caliber it would definitely make my short list. I actually like the color of the one above. It's real close to the color that (some day) I'd like to paint my Monte.
Old Mar 15, 2012 | 09:07 AM
Hi `Mike, I knew I had seen one orange b-4 on the `Web, but this one is the closest I could find...I like the Aston Orange better, but I thought the above may give you some idea...
I hope that your dream paint job comes true..Good Luck
Old Mar 15, 2012 | 10:08 AM
I love the Aston Martin & leave it Orange lol almost all Aston Martins are sweet
Old Mar 15, 2012 | 10:19 AM
03SSLE's Avatar
The color I have in mind is the burnt metallic orange that GM used on the Cobalt, but after seeing that Aston I may have to reconsider my choice.
Old Mar 16, 2012 | 07:18 PM
Zen's Avatar
Zen
Always liked the Aston Martins
Dec 19, 2014 04:53 AM
BeachBumMike
Apr 25, 2014 06:41 AM
BeachBumMike
Dec 22, 2013 04:42 AM
Dec 11, 2012 07:35 AM
