= 2015 Chevrolet Corvette Z06 Convertible Automatic=
A folding top and an automatic can't dilute the Z06. + Everyone can see YOU in your StingRay (LOL) Do you like it ? Do you want one ? I do, can you lean me a few $'s ? OK a lot of $'s ?
- Apr 2015
- By TONY QUIROGA
- Photography By FELIX SALAZAR
- Apr 2015
- By TONY QUIROGA
INSTRUMENTED TEST
“Convertible” and “automatic” are two words that can suck the joy out of a sports car the way fat-free and sugar-free can ruin a dessert. But that’s not quite the case with the Chevrolet Corvette Z06. The Z06 convertible proves that there doesn’t have to be a performance penalty for taking the roof off and adding a conventional automatic. Weight rises by an unnoticed 55 pounds, the structure remains stout enough for track duty, and the quick-shifting eight-speed has one additional gear to play with compared to the manual.
Admittedly, a manual Z06 coupe is a wilder ride than an automatic convertible. It’s the stick shift that makes it so. Sure, the automatic allows you to choose the gears, but most of the time you’ll just end up letting it shift for itself. Both can be had with the track-devouring Z07 package that includes, in addition to various aerodynamic enhancements, Michelin Pilot Sport Cup 2 run-flat tires. Thus outfitted, the convertible epoxies itself to the skidpad with 1.17 g of grip. The front tires break away predictably and the rears stay in place provided your throttle inputs remain smooth and slow. On canyon roads, the grip feels endless and you keep diving into corners faster and faster. The steering wheel dances in response to the cornering pressure, and the rack it controls is quick and accurate.
There’s no discernible handling difference between coupe and convertible. Both flow through corners and have ridiculous stick. We’ve previously tested two Z06 coupes, both equipped with the Z07 package, and one gripped better than this car while the other did fractionally worse. If anything, the lack of a roof and a glass hatchback likely brings the convertible’s center of gravity closer to the earth, making the job of the chassis slightly easier. The worst part is what the forces do to your neck.
Another form of physical abuse comes from the 6.2-liter supercharged V-8. With 650 horsepower and 650 lb-ft of torque pushing 3613 pounds, a two-speed Powerglide might be enough, but there are eight gears in this automatic, which are more than enough. A zero-to-60 run takes 3.1 seconds, a tenth behind our previous test of an automatic coupe. There’s so much power and torque present just off of idle that brake torqueing isn’t necessary to achieve a great time, but careful management of the rush of power is essential to avoid blazing the Michelins—move your foot too quickly and the rear tires light up faster than Cheech and Chong. Get it right, and the Corvette simply bolts. The car’s initial launch—1.3 seconds to 30 mph—is unbelievably quick for a rear-driver.
If the Z06’s g-force abuse still doesn’t have you reaching for the ibuprofen, the brakes will. Carbon-ceramic rotors are part of the Z07 package, and they work flawlessly in conjunction with the Michelin rubber. The braking distances from 70 mph to a stop improved the more attempts we made, settling in at 134 feet. On warm tires, the Corvette digs into the earth while the ABS pumps away, pressing you into the cinched belts.
Off the test track, the Z06 convertible behaves much like the coupe. There’s a brutality to the wheel impacts in Sport and Track modes. Your fatty regions will jiggle. You’ll feel out of shape. The convertible’s structure, however, remains solid and free from the shakes. Dial back to Touring mode and things go back to normal.
A blast of 91 decibels can be heard from the driver’s seat as the engine revs toward its 6500-rpm redline. It’s a deep, bellicose, NASCAR snarl and an antisocial shout that your Prius-driving neighbors might not like. Too bad for them. On the road, the Z06 proves to be so quick that the sound doesn’t last long. To keep from getting arrested, we settled for short blasts of acceleration. On the track, where the throttle can stay open for more than a few seconds at a time, the Z07’s aero package—which adds carbon-fiber slats, sails, and a wickerbilled spoiler to the body—stabilizes the car at speed but eventually drags down acceleration at high speeds.
With the top up, the small rear window restricts visibility. Dropping the top remedies any visibility and claustrophobia problems. With the top up, noise levels are low considering the wide tires and the throbbing V-8. But what’s really great about any convertible is rolling the top back, listening to the exhaust, and experiencing the freedom of ground-bound flight. Taking the top off of a Corvette Z06 delivers that magic—plus all the performance.
View Photos
View Photos
C/D TEST RESULTS:
Zero to 60 mph: 3.1 sec
Zero to 100 mph: 7.1 sec
Zero to 130 mph: 12.3 sec
Zero to 150 mph: 18.2 sec
Rolling start, 5-60 mph: 3.6 sec
Top gear, 30-50 mph: 1.7 sec
Top gear, 50-70 mph: 2.2 sec
Standing Ľ-mile: 11.3 sec @ 126 mph
Top speed (C/D est, drag limited): 185 mph
Braking, 70-0 mph: 134 ft
Roadholding, 300-ft-dia skidpad: 1.17 g
FUEL ECONOMY:
EPA city/highway: 13/21 mpg
C/D observed: 15 mpg
FUEL ECONOMY:
Specifications
VEHICLE TYPE:front-engine, rear-wheel-drive, 2-passenger, 2-door convertible
PRICE AS TESTED:$113,835 (base price: $87,020)< My dreams keep getting more expensive 4>Sure<
ENGINE TYPE:supercharged and intercooled pushrod 16-valve V-8, aluminum block and heads, direct fuel injection
DISPLACEMENT:376 cu in, 6162 cc
Power: 650 hp @ 6400 rpm
Torque: 650 lb-ft @ 3600 rpm
TRANSMISSION:8-speed automatic with manual shifting mode
DIMENSIONS:
Wheelbase: 106.7 in
Length: 177.9 in
Width: 77.4 in Height:48.6 in
Passenger volume: 52 cu ft
Cargo volume: 10 cu ft
Curb weight: 3613 lb
Wheelbase: 106.7 in
Length: 177.9 in
I've said it before and I'll say it again, those new 8 speed automatics ain't no joke. I'd take one over a stick any day. They are faster and better on gas. That's what we used to say about the standard transmission.
For those that want more infor (?)
Third Generation, 2015-Present
- Car News2016 Chevrolet Corvette Z06 C7.R Edition: The Closest You'll Get to the Le Mans Race Car
- Instrumented Test2015 Chevrolet Corvette Z06 Convertible Automatic
- Comparison Tests2015 Chevrolet Corvette Z06 vs. 2015 Nissan GT-R NISMO, 2014 Porsche 911 Turbo S
- FeatureFahrenheit Z06: The Maximum Operating Temperatures for the Corvette Z06 Are Insane
- Car NewsFor $5000, Chevy Will Let You Assemble Your Corvette Z06's Engine Yourself
- Car NewsWatch the 2015 Corvette Z06 Absolutely Destroy Virginia International Raceway
- Car NewsBusted! Jay Leno Pulled Over Driving a 2015 Chevy Corvette Z06
- Car News2015 Chevrolet Corvette Z06 Dyno'd at 585 Rear-Wheel Horsepower
- Car NewsThe Z06s Are Coming! The Z06s Are Coming! If You Ordered a 2015 Chevrolet Corvette Z06, It is Coming!
- Car NewsReport: 2015 Corvette Z06 Gets 13MPG City, 23MPG Highway
- Car NewsCommence Face-Melting: 2015 Chevrolet Corvette Z06 0–60 and 1/4-Mile Times Announced!
- Car News2015 Chevrolet Corvette Z06 Online Configurator Is Live! (Sorta)
- Car News2015 Chevrolet Corvette Z06 Spied in Ann Arbor—With Its Supercharged V-8 Revving! [Video]
- Car News2015 Chevrolet Corvette Z06 Deep Dive: What Makes the New Supercharged LT4 V-8 Tick?
- Car NewsHow Much for the Ăśber-Vette in the Window? 2015 Chevrolet Corvette Z06 Starts at $78,995
- Car NewsHeavy Hitter: 2015 Chevrolet Corvette Z06 Curb Weight Leaked
- Car NewsThe Sound of Unspecified Horsepower: 2015 Chevrolet Corvette Z06 Startup Caught on Video!
- Official Photos and Info2015 Chevrolet Corvette Z06 Convertible
- Auto Shows2015 Chevrolet Corvette Z06 360ş Photography: Holy Hell, This Thing Looks Downright Nasty [2014 Detroit Auto Show]
- Official Photos and Info2015 Chevrolet Corvette Z06: One Part ZR1, One Part Throwdown for Porsche
- Video2015 Chevrolet Corvette Z06: Every Detail, Courtesy of the Men Who Made It
- Car NewsThis Could be Chevrolet's Supercharged V-8 for the Corvette Z07—Or Not
- Future Cars2016 Chevrolet Corvette Z07 Spy Photos
- Future CarsExclusive: 2016 Chevrolet Corvette Z07 Spy Photos
They are all so expensive 4>Sure<
Rank In Performance Coupes and Convertibles
Which one do U want ? (2 drive/buy/steal) ?
1. Chevrolet Corvette Z06
Price:$79,995 -
2. Chevrolet Camaro ZL1
Price:$56,500 -
3. Chevrolet Camaro Z/28
Price:$73,300 -
4. Ford Mustang Shelby GT500
Price:$55,935 -
5. Dodge Challenger SRT / SRT Hellcat
Price:$46,690 - $59,290
Hi Brandon, I'd get the Z06 on a test drive & then race the other's for titles `Win >& then I'd have them...Return the Z06 & work a deal on trade & order a new Z07+ >
>Buckle Up >EnJoy<
When taking a recipe and working to make it even better… it pays to do your homework. In the case of Texas tuner John Hennessey, his ‘homework’ just so happens to be pinning sports cars open at full throttle and rocketing them up to eye-watering speeds. Not a bad gig.
Hennessey and crew have turned their attention to the C7 Corvette as of late, especially the new supercharged Z06. They’ve exercised a stock test vehicle on the dyno, benchmarked it through the quarter mile, but now it’s time to test the stock Z06 on a speed run through its eight-cog gearbox. Spoiler alert: it’s pretty fast.
RELATED: Take a closer look at the 2015 Chevy Corvette Z06
