wiper switch wiring problem.
Old Sep 2, 2013 | 11:38 PM
tiredvette's Avatar
Default wiper switch wiring problem.
hey guys, i just joined and need some info. i'm converting a 81 monte into an 87 ss and i need some help changing the 81 switch which is on the instrument cluster to the 87 switch which is on the steering column..... i'm not even sure these two switches will interchange. has anyone done this before?
Old Sep 3, 2013 | 04:44 AM
Hi TiredVette & welcome to the MCF
No, I've never done it before, but hopefully one of our member's maybe able to help you `if they know..(?)...Check back on your thread to see if anyone can answer...
You may have to be creative 4-Sure....Do you have a wiring diagram for both models ? Good Luck
Old Sep 3, 2013 | 10:21 PM
tiredvette's Avatar
i have a diagram for the 81 car but not the 87. basics for the car are 468 big block race gas motor,th400 3600 stall, 9in ford w/h case detroit locker and a set of 3:89 gears from jimmy johnsons 48 car. it still has never run yet but finally soon it will, i'm almost ready to start it up. by the way if anyone out there wants to part with their cheetah shifter 7002b let me know i'm still looking for that. i have just about everything else.
Old Sep 8, 2013 | 11:13 PM
tiredvette's Avatar
made some progress on the car today, painted the inside of one of the fenders and some of the ss stuff on the front. got one of my radiator fans from fedex friday so it's moving long a little bit. still a long way to go.....
Old Sep 9, 2013 | 06:26 PM
ohara's Avatar
by the looks of things you have a great project on your hands
keep us updated on the project and post some pics if you can.
Old Sep 10, 2013 | 09:13 AM
tiredvette's Avatar
are you sure you want to see it? it looks like hell with all the parts sitting on it half covered.
Old Sep 10, 2013 | 07:34 PM
A05C's Avatar
Specs on the motor? a 468 has a potential to make some power, but that's a pretty mild stall. Is it a street/strip car or a track only deal
Old Sep 14, 2013 | 01:03 AM
tiredvette's Avatar
general specs on the motor are.... 4 bolt .60 over block 12.5 to 1 pistons, total seal rings, .600 lift comp mechanical comp cam,7416 steel crank, 7/16 steel rods,ferrea wrist pins,gm 990 iron heads w/2.25 intakes and 1.88 exhausts, edelbrock air gap intake, 4781 850 holley carb, lit off by a msd 6al and a msd distributor, and for the exhaust hooker super comps heading down to a 3 in. all the way back pypes exhaust w/a pair of stainless flowmasters keeping things relatively quiet. it's your basic old style LS-7 454 that was destined for the corvettes and chevelles back in '70. it should go pretty well... and it is a very stock appearing street car.
bettare
Jul 25, 2015 11:31 PM
johnniep
Jan 25, 2012 01:13 PM
04chevyboy
Nov 10, 2011 07:39 PM
OVRPWRD
Feb 15, 2009 04:40 PM
jims875
Feb 5, 2008 07:32 PM
