help
help
i have a 2002 monte carlo ss that i pulled the motor and transmission was bad and the motor leaking oil and i ended up breaking one of the elbows for the fuel lines i tried to replace the elbow but the fuel line has like an inner hose inside the outer line how can i fix this
Dorman I believe sells a repair kit for this that you can buy at the local parts stores. Other options, buying replacement parts online, like Amazon. The fuel line coming to the engine and has those elbows should be nylon line with a corrugated loom protecting cover that slips off and back on.
Need help with removal of transmission
I have an 02 SS with a bad transmission. I am about 75% through the removal and now it just doesn’t want to move or separate. I can’t find any bolts I have not taken off yet. Can anyone who has successfully removed the transmission (with leaving the engine) help me locate these bolts that are holding it together?
6th Gen ('00-'05): Check this out on Your Montes!
JC Colon
01-22-2014 05:44 AM
6th Gen ('00-'05): Found out were my Gas is GOING!
JC Colon
23
01-17-2014 08:38 PM
