Replaced driver side axle and seal its leaking trans fluid
Old Feb 8, 2016 | 07:42 AM
Monsta _ carlo07's Avatar
Default Replaced driver side axle and seal its leaking trans fluid
I recently replaced my driver side axle and seal on my 07 monte and it still leaks trans fluid I'm lost can anyone help
Old Feb 8, 2016 | 09:28 AM
turbo monte's Avatar
I replaced one of them seals and used a Advance Auto parts seal as the replacement.... yep brand new seal leaked..... bought a seal direct from GM and no leaks!
Moral of this story, use GM gaskets and seals or plan on doing the job more then once!!
Also make sure the axle is in the whole way and make sure there is no gouges in the seal race etc that could cause leaks
Old Apr 17, 2017 | 06:03 PM
Nunchucks's Avatar
Do you think the driver side axle seal could be replaced by just removing the strut to steering knuckle bolts, while still leaving the axle nut tightened on the other end of the axle?
Old Apr 18, 2017 | 03:19 AM
Idk why you would want to do this..... You take them bolts out and you need a alignment... And I don't believe you will get enough out of it to get the axle out. Need to remove the lower ball joint.
Or remove the hub and let the ball joint alone
Old Apr 18, 2017 | 04:07 AM
Nunchucks's Avatar
wouldn't you need an alignment if you took the balljoint out? I heard you should get an alignment anytime you remove/replace any suspension components strut, tie rods, ball joint. Etc. maybe I just got some bad info? Still can't find the correct axle nut torque. Some say 118 ft/lbs, some say 159 ft/lbs.
Old Apr 20, 2017 | 07:59 AM
The lower ball joint just bolts in, there is no "adjustment" where you would unbolt so no alignment would be needed.
