new, need help
Old Apr 8, 2007 | 02:12 PM
jzeiger07's Avatar
Default RE: new, need help
so... i managed to pretty much take out the entire back seats except i cant get two bolts off, any tips on how to loosten them up?
Old Apr 9, 2007 | 02:15 PM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
some type of penetration lube like PB blaster should do the trick... although I don;t know why you souldn;t be able to loose them since they would not be exposed to the elements... What are they connected to?
Old Apr 9, 2007 | 02:55 PM
jzeiger07's Avatar
so im an idiot and was takin off the wrong part but now that i got the rear deck off, im just not sure about the wiring, i was told in gm cars in the rear deck, the possitive wire was black but when i removed the speakers theres no black one, there only a white and tan on the right and white and red on the left side so what do i do here? sorry for all the questions i havent had any1 around to teach me this stuff
Old Apr 9, 2007 | 03:02 PM
Mrrench's Avatar
Tan and Red are the positive ones
White are the negitive ones
Old Apr 9, 2007 | 03:28 PM
jzeiger07's Avatar
thanks. do i cut the ends off so then i can link the wires together and tape it up or what
Old Apr 9, 2007 | 03:41 PM
Mrrench's Avatar
I dont believe in cutting ends off of the harness (thats just me).
I normally would make a small harness from the one in the car to the speakers (again thats just me)
Old Apr 9, 2007 | 03:48 PM
jzeiger07's Avatar
how would i go about making one?
Old Apr 9, 2007 | 04:04 PM
[align=center]
ORIGINAL: jzeiger07
[/align][align=center]Hi `Josh, It's sounds like you have taken on a project without a plan.[/align][align=center]I do it all the time : ) I'm great about tak'in things apart : ), but it's gett'in it back[/align][align=center]2-gether that I have the problems.[/align][align=center][/align][align=center]I would search out a friend with knowledge or join a local car club with [/align][align=center]members that have knowledge of Audio components.[/align][align=center]Or Wait & Save[/align][align=center][/align][align=center]Here's a link that might help[/align][align=center][/align]Speaker Wire: Choosing and Installing
[:-]Click link below [:-]
http://www.crutchfieldadvisor.com/S-...ingcenter/car/
Old Apr 9, 2007 | 04:10 PM
Mrrench's Avatar
Its easy to make
If the plug end has female connections then you would need to get male connectoins to go there,
Then take some wire and run it from the plug to the speaker,
On tha end you will need to put female ends on the wire
Crimp both ends of the wires that you just made,
Make sure you plug the pos. end on the correct post
They dont have to be that long
You can get a wire crimpping set at most stores. Should be around 10 bucks or so
Old Apr 10, 2007 | 05:07 AM
jzeiger07's Avatar
thanks for the help.
jaydflash
Aug 29, 2014 03:38 AM
blackmonte781
Oct 3, 2011 01:38 PM
rmase182ls
Feb 28, 2011 03:57 PM
00SSsupercharged
Apr 29, 2009 09:45 PM
mickey
Aug 23, 2006 05:31 PM
