hvac air not cold on driverside when ac is on
Old Aug 26, 2019 | 06:31 PM
riverfront4life1's Avatar
Default hvac air not cold on driverside when ac is on
when ac is on driverside is hot rightside cold
Old Sep 2, 2019 | 05:12 PM
What year do you have?
I found in my 2004 SS, when I had to change the evap core, the pivot points (hinge, whatever you want to call them) for the blend door was very tight. So much so, I suspect the actuator could not move it to much. While I had everything apart, a little bit of sanding and some lube on those points and now it all appears to work perfectly.
Nathan Phillips
May 20, 2019 10:34 AM
Onion39
Mar 20, 2018 02:42 PM
shynativegrl
Apr 12, 2015 07:00 PM
joe34
Oct 10, 2013 10:33 AM
S.O.G.
May 25, 2012 09:08 PM
