help! need more hp!
Old Aug 23, 2013 | 09:36 PM
montecarlossboosted's Avatar
Post help! need more hp!
I have a 2003 monte carlo ss and need to get it fast!. best ways to get my 3.8 n/a up too 300whp? engine swap? tune? what is the best and cheapest way to get there
Old Aug 23, 2013 | 11:11 PM
In order to get to that amount of power you're gonna have to get boost, turbo charge it or top swap it and super charge it.
Old Aug 23, 2013 | 11:50 PM
Griffindor's Avatar
Cold air intake, performance cams, high performance distributor, high performance plug wires and coil packs. Performance rockers and valve springs would be a cheap way to gain some performance. Also make sure your engine mounts are tight. If they are loose consider flipping the rubber mounts inside the two front engine mounts. You can google that to see more about it.
Old Aug 24, 2013 | 05:55 AM
Definitely a turbo.
ZZPerformance - ZZP Z3 Turbo Kit #ZZ-Z3TK
If you want WHP, then you should probably look into the intercooler option.
Old Aug 24, 2013 | 07:24 AM
Does a 2003 Mont Carlo 3.8 have a distributor? Where is it?
Old Aug 24, 2013 | 11:41 AM
nitehawkjcb's Avatar
Go turbo + intercooled
Then get ready for your transmission to need a rebuild
jaydflash
Aug 29, 2014 03:38 AM
GTHSS
29
Jul 23, 2014 10:27 AM
TheVille87
May 10, 2014 11:28 PM
VictoryRedSled
Jul 2, 2013 01:06 PM
sprfrk2005
Dec 22, 2009 03:57 PM
