gas!! resanator??
Old 02-26-2011, 03:13 AM
dupree155's Avatar
Default gas!! resanator??
i have a 02 3.8l and im burning too much gas i used a half of tank and only drove 90 miles.. no cel on or anything had my cat changed recently also cause it was bad changed 02 sensors and plugs/wires ... could it be my resonator? would appreciate any help thanks
Old 02-26-2011, 08:31 AM
first things first, have you checked your fuel pressure to see if it is where it needs to be? if not, you could have a leak somewhere in you lines, or one of your fuel components have gone bad. i had something similar happen, and it was the fuel pressure regulator..
Old 02-26-2011, 08:35 AM
Your resonator ONLY mufflers the drone from your exhaust system, has nothing to do with gas consumption.
Fuel filter could need to be changed, your injectors could be clogging, were both oxygen sensors changed or just the rear one near the cat?? Air filter could be dirty.
Old 02-26-2011, 11:12 AM
dupree155's Avatar
Thanks I will look into that...and yes I changed both o2 sensors and the fuel filter had MT injectors checked also they are good
Old 02-26-2011, 03:36 PM
Default Resonator
[quote=ChibiBlackSheep;300733]Your resonator ONLY mufflers the drone from your exhaust system, has nothing to do with gas consumption.
Slightly off the subject: if I remove the resonator from my '07 LT, would the exhaust sound a whole lot louder or just a little? I'm trying to find out how to boost the sound SLIGHTLY - I don't want to disturb the neighbors, and I'm not looking for a motorcycle-like rumble. Any suggestions? Thanks for any advice...
Old 02-26-2011, 07:41 PM
Just swap the mufflers to change the sound slightly. The resonator delete will increase the nasty drone inside your cabin.
Old 02-27-2011, 07:29 PM
dupree155's Avatar
Could it possibly be My cat and just Not throwing the cel?
Old 02-28-2011, 08:27 AM
SpinEm_90's Avatar
Heyy! Welcome to the forum! Good luck with it!
Old 02-28-2011, 03:27 PM
You said you already changed the cat, so it wouldn't be hurting you.
Old 02-28-2011, 05:59 PM
bad or clogged egr will kill your mpg. i don't trust them things at as far as i can throw em.
Quick Reply: gas!! resanator??
