2004 Monte Carlo won't cranks but doesn't start
Old Aug 14, 2017 | 12:05 PM
Teresa Morla-Harden's Avatar
Default 2004 Monte Carlo won't cranks but doesn't start
I just put my Monte Carlo back together it had a blown head gasket. So I changed the gasket got the head redone. After I put all together I wasn't getting any fuel to the fuel rail so I changed the fuel pump and the filter. Then I changed the battery because I wasn't putting out enough cranking amps. Then I changed the starter because their was smoke coming from the starter I think I burned out the bushings from cranking it. From all of this it won't start. I'm lost of what may be the problem. one last thing I also changed the Ignition Relay. Can someone give me some help???????????????
Old Aug 15, 2017 | 08:29 PM
plumbob's Avatar
Hey Teresa,
Your problem might be the ignition switch housing. It's been a common problem lately. It's tied into the theft deterrent system. If it or the ignition look cylinder go bad it will disable fuel delivery. Have you checked for codes? Do you have anything weird happening with dash lights and gauges, or a flashing battery or security light?
BTW...GO HAWKS!!!
Old Jun 10, 2019 | 05:33 AM
Old03SSDriver's Avatar
Default Was it fixed?
So what did you do to fix it?
Michaelmyers11u9
Nov 15, 2019 09:41 PM
N_robertson
Oct 2, 2017 06:19 PM
N_robertson
Sep 29, 2017 04:54 PM
N_robertson
Sep 28, 2017 06:09 PM
