2001 MC SS starting problem
Old Dec 4, 2010 | 10:20 AM
WV896's Avatar
Default 2001 MC SS starting problem
I have had this problem since I bought the car but now am getting sick of it. First off, when you go to start it for the first time of the day or after it has sat awhile it will fire right up. But, if you shut it down and try to start it right back up or while its still warm you almost have to give it a small amout of gas pedal or it will not start. Help?
Old Dec 7, 2010 | 11:35 AM
SpinEm_90's Avatar
Heyy! Welcome to the forum! Hmm I'm not quite sure what that could be but hopefully one of lthe other members on here will be able to help =)
Old Dec 7, 2010 | 11:46 AM
Bitchnbobb's Avatar
I had a simular problem awhile back on our 02 Chevy venture. Turned out all I had to do was change the head gaskets. I had antifreeze dripping into one cylinder and it made the engine run like crap till it all burned off.
Im not saying thats your problem, Im just saying theres alot that can go wrong. Without being under the hood its hard to say what it could be.
Old Dec 7, 2010 | 05:50 PM
ladderman100's Avatar
Default trouble codes
take it to a dealer or someone with a diagnostic scanner...check for codes... it sounds like a bad throttle position sensor....but again it should have a trouble code if its bad....i was a mechanic a while back...for 20 years...ase cert.
Old Dec 7, 2010 | 08:13 PM
Crusader SS's Avatar
Welcome, you couldn't be in better hands... You'll get the help you seek here...
Old Dec 9, 2010 | 03:23 PM
Jomao_o's Avatar
Welcome to the site
Old Dec 15, 2010 | 09:28 AM
NateBauer's Avatar
Default Starting Problem
From what you say, it is almost as if you are not getting enough fuel. Maybe the fuel filter?
jet1390
Dec 16, 2010 04:04 PM
Shandley
Nov 6, 2010 03:48 PM
hank635
Jun 14, 2010 02:30 PM
Plengr
Oct 23, 2009 08:47 AM
