02'Monte Carlo SS engine fire
Old Oct 6, 2015 | 01:33 AM
2002SS's Avatar
Exclamation 02'Monte Carlo SS engine fire
Hello everyone, I am new to this forum but have owned my white 2002 Supersport for several years. While my Wife was driving home from the grocery store last Friday she sensed a loss of power and noticed steam/smoke from under the hood. She immediately pulled over began unloading the groceries within a minute someone had stopped and assisted her at which time my wife lifted the hood to discover that the engine was on fire and again, within seconds someone came running from across the street with a fire extinguisher and put the engine fire out. just some stranger! Probably saved the engine and car really. after looking into this I learned about a recall on this years (2002) model for engine fires. Has anyone had this happen and is there anything I can do about it now that it has already happened? Thanks for your time.
Old Oct 6, 2015 | 09:33 AM
turbo monte's Avatar
all you can do is fix the damage yourself or claim it on your insurance if you still have full coverage. if you never got the recall done thats your fault not GM's fault is how they will look at it.
on a side note a lot of people lost there 3800 platform cars (monte, regal, gp, impala, etc) from engine fires so your not the only one. sorry to hear about this and i hope everything works out for you!
Old Oct 7, 2015 | 02:01 AM
2002SS's Avatar
Thumbs up Thanks Turbo Monte!
I'm pretty sure I can get it back on the road. got several parts and pieces that were damaged by the fire from the salvage yard. The most repairs will be the upper intake plenum, the power control module engine harness, and on of the fuel lines leading to the fuel rail. I've done the plenum before so I'm good there. Thanks for responding!
Old Oct 7, 2015 | 02:58 AM
2002SS's Avatar
anyone know the part number for the 2002 3.8 PCM engine harness?
Old Oct 7, 2015 | 08:26 PM
I think your best bet is to go to the junk yard an pull the harness you need.. because it will cost you from the dealer..
with search term: ecm
Show all Buick PartsShow all Chevrolet PartsShow all Pontiac PartsShow all Parts
P.C.M. MODULE & WIRING HARNESS; W19-27 P.C.M. MODULE & WIRING HARNESS
(L36/3.8K); (L36/3.8K,L67/3.8-1); (LA1/3.4E)
BKS: BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65); BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
ECP: MODULE,POWERTRAIN CONTROL POWERTRAIN CONT MODULE(K29)
EMS: EMISSION SYSTEM CALIFORNIA, LEV CALIF EMIS LEV(NC1); EMISSION SYSTEM CALIFORNIA, SULEV SULEV CALIFORNIA EMIS SYS(NU3); EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7); EMISSION SYSTEM,CALIFORNIA, ULEV CALIF EMIS SYS(NC8); EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
ENG: ENGINE GAS, 6 CYL, 3.4L, MFI, HO 3.4E(LA1); ENGINE GAS, 6 CYL, 3.6L(220 CID), SFI, V6, ALUM, 60 DEGREES, GM 3.6-7(LY7); ENGINE GAS, 6 CYL, 3.8K, MFI, V6, HO (ERV6 SERIES) 3.8K(L36); ENGINE GAS,3.8L(3.8-1),SFI,V6,SUPERCHARGED 3.8-1(L67); ENGINE,3.1L(3.1M)6 CYL,V6,MFI,HO 3.1M(L82); ENGINE,3.8L,V6,SFI 3.8-2(L26); ENGINE,6 CYL,3.1J, SFI, V6 GM 3.1J(LG8)
RAT: RATIO TRANSAXLE FINAL DRIVE 3.05 3.05R(F83); RATIO TRANSAXLE FINAL DRIVE 3.29 3.29R(FR9)
TRN: TRANSMISSION AUTO 4 SPD, 4T65-E, HEAVY DUTY 4-SPD AUTO TRANS(MN7); TRANSMISSION AUTO 4-SPD, 4T65-E 4-SPD AUTO TRANS(MN3); TRANSMISSION,AUTO 4 SPD,HMD,4T65-E ENHANCED ELECTRONIC 4-SPD AUTO TRANS(M15)
Showing Genuine Parts that fit your 2002 Chevrolet Monte Carlo
Change Vehicle001HOUSING. Air Cleaner To Carb/Throttle Body Mounting
HOUSING,A/CL LWR. Required: 01
For: W 3.1J(LG8) (2003-2005) (2003 - 2005).
More Details...
$104.0410355050 View Product 003HARNESS. Engine Wiring
HARNESS,ENG WRG. Required: 01
For: W19-27 3.8K(L36) (2001-2002) (2001 - 2002). $926.8310323585 View Product 003HARNESS. Engine Wiring
For: W19-27 3.4E(LA1) (2001-2002) (2001 - 2002). $1149.1910302601 View Product 004INSULATOR. Air Cleaner Intake. Air Cleaner. Air Cleaner and Silencer. Engine Coolant Recovery. Manifold to Cylinder Head. Theft Deterrent or Frt/Rear/Side Object. RESONATOR.
INSULATOR,A/CL HSG(03.270). Required: 02
For: W (2000-2003) (2000 - 2003).
More Details...
$7.6425346092 View Product 005CONNECTOR. Chassis Electrical. Door Window. Emission Control System. Instrument Cluster Warning.
CONNECTOR,MDL-ENG CONT(INCLS SEAL,COVER,RETS)(W/O LEADS)(80-WAY FEMALE USE TERM 12084912 18 GA & TERM 12084913 20 GA). Required: 02
For: W (2003-2005) (2003 - 2005).
For: W 3.1J(LG8),3.8K(L36),3.4E(LA1) (2000-2002) (2000 - 2002). $47.3612167308 View Product 006MODULE. Emission Control System
MODULE,PWRT CONT(REMAN)(CODE DFJM, DFJN)(REQUIRES REPROGRAMMING)(ACDelco #12209614). Required: 01
MODULE,PWRT CONT(REMAN)(CODE DFJP, DPNR)(REQUIRES REPROGRAMMING)(ACDelco #12209614). Required: 01
More Details...
$283.0412209614 View Product 006MODULE. Emission Control System
MODULE,PWRT CONT(REMAN)(CODE DBAK)(CODE: YCZR; DLHL)(REQUIRES REPROGRAMMING)(ACDelco #12209624). Required: 01
MODULE,PWRT CONT(REMAN)(CODE DBAL, DPSB)(CODE: YCZR; DLHL)(REQUIRES REPROGRAMMING)(ACDelco #12209624). Required: 01
More Details...
$655.0812209624 View Product
While every reasonable effort is made to ensure the accuracy of this data, we are not responsible for any errors or omissions contained on these pages.
Please verify any information in question with a sales representative.
© 2015 Wholesale GM Parts Online | Policies
WEB01
Old Oct 13, 2015 | 12:47 PM
2002SS's Avatar
Thumbs up Thanks ZJerry
I appreciate the feedback "Z", it's funny because I called the Chevrolet parts dealership and he couldn't find the part number. He mentioned I would need to piece it together. So, I had already concluded the wrecking yard would be my best option. Especially since it sells for $150.00 and $75.00 if I pull it. So, I will be doing that this Friday. Any precautions you can think of before I hit a wall or something? Appreciate your time and knowledge on this matter! Thanks!!
