02 monte carlo wont start
I have a 02 monte carlo. I had some overheating issueso and had to replace my radiator and also replaced the head gaskets and when I got the engine back together. The car now won't start. It cranks but nothing else. I have fuel it seems to have good compression. Any help will help
Does it have spark?
Sounds like something got missed in the reassembly. You may want to back track your reassembly steps and see if a wire didn't get put back right. It happens to the best of us. Lol
Air, spark and fuel are the magic formula. Are you sure all the plug wire got put back in the right order? If it cranks you can rule out PCM or anti-theft/ ignition problems.
If you crank (as Plumbob said, rules out anti-theft and dead battery), you validated compression and spark. I assume no blocked air intake... Next, do you know that you have fuel pressure? Can you hear the pump hum when it primes?
