ZZP PCM 1.0 HELP!
Old Oct 7, 2007 | 11:16 AM
White05LT's Avatar
Default RE: ZZP PCM 1.0 HELP!
Well the PCM is being sent back to ZZP. Zooomer needs to look into this. I did noticed that when I use my scanner to clear the SES codes, the oil pressure gauge functions normally for a few seconds and then flatlines again followed by the SES returning. I think this is just a matter of tweaking it, and installing the Rear O2 Delete. The car is still running great.
Old Oct 7, 2007 | 09:25 PM
04 Intimidator's Avatar
ORIGINAL: White05LT
You are refering to having Zoomer set a permanent clear in the PCM for the rear O2 correct? I just want to make sure you don't purchase the O2 simulator as it doesn't work on 2004+ Monte's. In the past they sensor just checked O2, now they also check temperature and it hasn't been discovered where that is in the PCM yet.
zipper
Jun 1, 2015 07:50 AM
The_Maniac
Nov 10, 2010 09:42 AM
tlip06
May 1, 2008 09:25 PM
tlip06
Mar 1, 2008 02:59 AM
