5th Gen ('95-'99): It wont start
Old Jan 14, 2020 | 10:47 PM
Tamjaz1028's Avatar
Default It wont start
I have a 99 monte ls it will try to start but dont we replaced the crank sensor the cam sensor the battery the computer over 3 yrs ago and now when its real cold out it wont start plz help
Old Jan 15, 2020 | 12:28 AM
nitehawkjcb's Avatar
Does it crank? If not, it could be a VATS issue.
Old Jan 15, 2020 | 03:58 AM
Tamjaz1028's Avatar
This is gonna sound dumb but what is vats
Old Jan 15, 2020 | 10:49 AM
JackDW - 852's Avatar
Vehicle Anti Theft System - Basically the key. There is a resistor embedded into the key with provides a signal to that allow the car to start. If they go bad, the car wont start.
Do you have another key? If so, try another key. If it starts the first key is bad.
A very simple "starting" point for a no-start condition.
Old Jan 15, 2020 | 11:47 PM
Sometimes the contacts inside the ignition switch get worn out, other times the small wires going to the switch lose contact, the contacts on the key wear out... Definitely try another key if you have one. There is a VATS bypass to avoid replacing the ignition switch. This page has a lot of useful info on that procedure http://thealdensorg.dyndns.org/vehic...BypassVATS.pdf
Deshun Deathbefore Dishonor
Jul 16, 2019 07:39 AM
MonteMama87
Apr 24, 2014 05:47 PM
owens91
Jul 5, 2013 03:14 PM
sjplaya33
Dec 9, 2010 07:34 PM
victoryred05
Jun 18, 2008 09:17 AM
