Windshield wiper not working (passenger side only)
Old Jun 5, 2017 | 01:30 PM
c_mtz90's Avatar
Default Windshield wiper not working (passenger side only)
2000 Monte Carlo ss
Has anyone had problems with only one wiper working? My passenger side wiper only moves 3 inches while driver side works perfectly.
Old Jun 7, 2017 | 02:35 AM
Imp42017's Avatar
Well that is odd really. Seeing there is only 1 motor for the wipers. So there must be an issue with your Arm for that side. It could be binding or broken. I guess it also could be that splines that the wiper sits on is bad or if it isn't one like that but has a screw that holds it on
Old Jan 11, 2018 | 03:59 PM
Jordan Williams's Avatar
Default Did you ever get this figured out
I am having this same problem right now, just wondering if you found the problem or what is causing it and the fix
Old Jan 13, 2018 | 10:42 AM
At the base of the wiper arm is a black cap covering a nut. Pop the cap off (may need a small flat head screw driver) and ensure the nut is tight. If it's not tight, the wiper is probably moving just enough until the weight of the arm cannot handle it.
It's an easy, fist place to check.
Old Jan 13, 2018 | 04:16 PM
Thanks for the reply. I got it figured out, my wiper was frozen to my windshield, and when I turned it on It filled the splines with aluminum. Cleaned it out, and it was working fine.
