6th Gen ('00-'05): powersteering cooler line
Old Jan 11, 2018 | 01:11 PM
frankboni's Avatar
Default powersteering cooler line
'03 SS, 3.8 L needs a new power steering cooler line. Old one leaking. I have a quote for $433.00, part and labor, from a nearby mechanic. Fair or rip off?
Old Jan 11, 2018 | 05:38 PM
that sounds high because its not hard to do.
Old Jan 13, 2018 | 03:57 PM
swims350's Avatar
that line is also not cheap it's very long, runs down and around the front of the engine to the driver's side and back. I looked them up local at chain parts stores and it's around $150 or more for the line itself. I would think changing may require the pump to removed from the engine and then reinstalled so a lil time consuming and labor intense IF that has to be done. I could be wrong I haven't done one yet but I have to on my wife's 01 ss her's had been patched up several times before we got it.
If I'm thinking of the right line? I hope don't want to give wrong info
Old Jan 13, 2018 | 07:04 PM
Depending on where its leaking, the line may be able to be patched - cheaply and easily. The cooler line isn't running much pressure
