Windows Letting water in like crazy.
Old Apr 30, 2011 | 04:10 PM
shmew22's Avatar
Default Windows Letting water in like crazy.
Title pretty much says it, when it rains or i wash it or whatever my 02 monte lets water leak into the doors and into the floorboard like crazy. I have bought new seals for the outside of the windows thinking that may have been what the issue was but it still pours in. Having spent 80bux a seal needless to say im not happy about the issue... any ideas on what i could do to fix this?
Old Apr 30, 2011 | 05:14 PM
CashMoney's Avatar
welcome to the forum. please check out this forum post as it may be helpful to you
https://montecarloforum.com/forum/ge...ripping-27767/
Old Apr 30, 2011 | 07:43 PM
Budsjlm's Avatar
do you have a sun roof?
Old May 1, 2011 | 09:59 AM
BIGAL131's Avatar
Are you sure that the water is coming through your door and not through the cabin air filter section in your cowel and leaking down through the firewall and onto your passenger side floor? There is a fix for this issue if that is the case with your problem.
Old May 2, 2011 | 05:33 AM
shmew22's Avatar
Positive it's the window. Took off the panel and ran water over it and you can see it just pour in
Old May 5, 2011 | 08:01 AM
JaxJim's Avatar
My windows let a lot of rain in too. When that happens, I roll them back up.
There should be a seal at top of the door (on the outside) that presses against the window, and keeps most of the water from getting inside the door. Any water that does get in should drain out the holes at the bottom of the door.
If the water is pouring in as you describe, it should be fairly easy to find the source. Good luck.
SamL
MCF Website Problems & Issues
Feb 1, 2014 06:12 PM
Aug 12, 2012 09:27 AM
VenomIntimidator
31
Nov 2, 2011 04:13 PM
Chadgee
Sep 23, 2009 06:23 PM
Brooke
Oct 17, 2007 04:35 PM
