white smoke out of exhaust
While doing all this, check the plastic UIM (not gasket, the actual UIM) for damage around the EGR stove pipe (it goes between two coolant tubes that flow coolant through the throttle body). The heat from the EGR tends to make the UIM brittle there, develop a leak and now the car might exhibit symptoms like a bad head gasket when it was something far easier/quicker/cheaper to fix.
STUMPMI
Oct 9, 2013 09:15 AM
SoCal01Monte
Jun 25, 2012 10:30 AM
ltrain925
Dec 22, 2009 11:39 AM
