Whining/Grinding Left hand turns only
Old Feb 11, 2011 | 04:55 PM
2005 SC SS's Avatar
Default Whining/Grinding Left hand turns only
  • I have had my 2005 SC SS since I ordered it new in 2005
  • Extended warranty until 1.08.11 - so it's done
I have a grinding or whining sound when I acclerate and turn left only and here are some other facts:
  • ISS replaced by dealer 5/2010 when I first heard a noise
  • Passenger side (opposite side) wheel bearing replaced by dealer 4/2010 when I first heard anything and felt it was loose
Since, I've had this shaft replaced and the wheel bearing, I'm suspicious that it's the ISS again, but could be. It seems to do it more when cold, but not always the case. Even warm, any left turn will cause "power steering pump whine" to describe it, but it doesn't sound like it's coming from the power steering pump. Any ideas? Any help is appreciated!
Old Feb 11, 2011 | 11:12 PM
Did you check your power steering fluid?
Did you spray the knuckle on the ISS to grease it?
Are you sure the wheel bearings aren't just bad again? I was going to suggest that since it's only turning left
Old Feb 12, 2011 | 09:26 AM
2005 SC SS's Avatar
Default Found the issue
Thanks. I was already down in the garage this morning and took everything off to the wheel hub and checked it and it's definitely the wheel bearing. You'd think the dealership would have replaced BOTH sides at the same time...but I think I'll be doing my own work on it anyway from now on since it's out of warranty (like I do my '68 Camaro)! A pair of wheel bearings/hubs on order. Thanks for replying. I appreciate it.
Old Feb 12, 2011 | 10:16 AM
Here's a nice little write-up on how to change the hubs on a grand-prix and since it's the same car it can help you.
http://www.paulstravelpictures.com/G...ent/index.html
Old Feb 12, 2011 | 11:45 AM
2005 SC SS's Avatar
Default Thanks again
Oh yeah, I've got that down... The only thing I've ever been worried about was the ABS and speed control volume sensors, but it's a simple plug for ABS. You guys are excellent. I love this site! Thank you very much!
Old Feb 12, 2011 | 01:44 PM
It is nice that it's all built in and easy to do, but when one of those sensors fail you just can't replace it
So it has its pros and cons lol
Sean_G
Jun 13, 2014 09:46 AM
Dubstepticon
Oct 30, 2013 12:08 PM
Andrew
Apr 18, 2013 09:06 AM
forklift
Oct 20, 2011 09:32 AM
biggriggs
Nov 11, 2008 08:55 PM
