Loses power on hard left turns and trans slipage
Old Oct 3, 2011 | 11:52 PM
forklift's Avatar
Default Loses power on hard left turns and trans slipage
So my daughters 99 seems to lose power on hard left turns. Its regardless of how much gas is in the tank and the power just seems to drop a bit, maybe a few hundred rpms and comes back.
Also, sometimes the trans slips when you pull off the light or stop sign, then all is fine, something normal or happens a lot?
Old Oct 3, 2011 | 11:59 PM
how many miles on her car? or on the trans
Old Oct 4, 2011 | 08:58 AM
forklift's Avatar
Old Oct 4, 2011 | 02:12 PM
monte07's Avatar
when was the last time you did rutene things to it like oil's air filter things like that? some times older fluid seems to make powertrains run a little slugeshly
Old Oct 4, 2011 | 02:14 PM
monte07's Avatar
i would do that first before thinking it is much more serios problem nock the odveus out the way then go from there. when under the car check every thing espessially the boots on the axels as well as any thing driping or worn
Old Oct 4, 2011 | 06:56 PM
Warhorse's Avatar
Stupid question, how much fluid in the trans? Could be low....
Mike
Old Oct 5, 2011 | 07:33 AM
forklift's Avatar
yeah I did a fluid/filter change a few months ago to fix the leak with the trans pan, I should have said that
Old Oct 5, 2011 | 08:33 AM
The only thing I could think of is a possible wiring problem, or a problem with the right wheel hub assembly.
Old Oct 5, 2011 | 03:35 PM
mwjames's Avatar
Is there any check engine lights on? If no lights are on run it 10 minutes or so doing the problem behavior and see if it kicks on then
Old Oct 20, 2011 | 08:54 AM
forklift's Avatar
no engine lights and I dont think its a hub as the engine actually takes a few hundred RPM dive on those hard lefts, its not like the trans is slipping on them
I think the off the line problem is a solenoid in the trans, just a guess
