Whine
Old Sep 4, 2010 | 01:41 PM
captaindamnit's Avatar
Default Whine
On my 05 Supercharged, I have come to notice a whine from the engine. It maily happens after a little bit of "aggressive driving". I have also come to notice that i REALLY WHINES when i am turning.. not like a hard turn but say i was turning a street corner at like 15 mph, as i accellerate it get really loud. Is this supposed to be happening? Note: it really only happens after a bit of harder driving. If i am just defensively driving and just cruising... no whine(atleast that i can hear).
Old Sep 4, 2010 | 01:57 PM
Hi Captain,
How many miles on your Monte now ?
It sounds like it could be a bad power steering unit, or
low on fluid ? (that's a guess: )
or
Many members have reported that they have had problems
with the intermediate steering shaft. It's a issue
with several 6 Gen Monte's.
If it is the shaft the current fix is to replace the shaft
entirely which uses a nylon internal substance instead
of grease. Many member's have just re greased their
shaft : )
I hope one of our expert tech members post their opinion,
or solution on what it may `be.
It's difficult to diagnose from just words in a post, but
I hope that our tech member's can help you 4-Sure.
Good Luck
https://montecarloforum.com/forum/se...earchid=290062
Above is from our Forum Search Engine
on same or similar problems.
Click & Explore
Old Sep 4, 2010 | 01:59 PM
I have about 87k miles on her now.
Old Sep 4, 2010 | 02:18 PM
Hi Captain,
One thing my grandfather taught me to check on noises
from the engine area is to use a long screw driver
(or if you have access to a auto stethoscope) so you
can listen to parts on your engine that may cause a `whine
and help pin point a problem. I would listen to the
idle & tensioner pulley's, as well as the
alternator & power steering pump.
This has helped me pin point a problem,
but again this is just one way.
I don't know if you are mechanically inclined or hopefully
have a trusted mechanic that can check it out.
Check back on your thread to see what our expert tech
member's post...*I am no expert 4-Sure...
Good Luck
Old Sep 4, 2010 | 03:08 PM
nitehawkjcb's Avatar
Check your power steering fluid.
kweef
Jan 6, 2009 11:35 AM
mrl390
Dec 2, 2007 12:19 AM
cain45
Aug 20, 2007 08:57 AM
SoCalSS
Aug 18, 2005 12:45 PM
SoCalSS
Aug 13, 2005 04:51 PM
