Where is the Horn Relay in a 1978 Monte?
Old Feb 8, 2013 | 07:27 PM
MonteManiac's Avatar
Default Where is the Horn Relay in a 1978 Monte?
Can someone direct me to the horn relay? I can not seem to find this information anywhere online or in my manuals.
Old Feb 8, 2013 | 07:39 PM
Did you look under dash by the steering column ?
Could be outside on firewall by master cyl..
Old Feb 8, 2013 | 08:13 PM
The horn relay should in the power distribution box under the hood...
This what the horn relay may look like...
When you hit the horn button do you even hear a clicking sound?
If not..its very possible that the wire running thru the column to the horn ..maybe damaged..or even severed...
Thus its not makeing contact with the relay switch...
Old Feb 8, 2013 | 11:18 PM
Default Thanks guys,
I will check it tomorrow in the daylight and let you know how it goes.
Old Feb 9, 2013 | 09:50 PM
Default No Luck Yet
I looked everywhere you guys suggested. I still can't find that sucker. I think it might be behind the triangular kick panel in front of the driver side door under the dash. I had to change out a water pump today so I didn't get around to taking that panel off. It must be behind there but I still am not sure. Has anyone actually changed out the horn relay on a 78 Monte? Could it be missing from the fuse panel?
Old Feb 10, 2013 | 07:52 AM
You could always stop at the parts dept at a Chevrolet Dealer to findout forsure!
Old Feb 10, 2013 | 11:05 PM
Default David, great idea!
I will see if I can do that this week!
Old Feb 11, 2013 | 07:55 AM
03SSLE's Avatar
It looks like the pic that Stumpmi posted and plugs into a connector mounted vertically on the left (driver) side inner fenderwell.
jeffrae
Feb 20, 2017 10:02 PM
sassytaz66
Mar 24, 2015 05:42 PM
MJClemm
Dec 12, 2012 02:21 AM
00'MonteSS
Apr 28, 2011 12:59 AM
odessadude
Oct 7, 2007 08:44 PM
