Wheel alignment for 2001 monte ss
Old Aug 15, 2008 | 09:02 AM
rickyk55's Avatar
Default Wheel alignment for 2001 monte ss
I was looking for the factory specs for an alignment all the way around. Camber, caster toe, steer ahead, thrust angle. Any help would be great. I cannot find any info anywhere.
Old Aug 15, 2008 | 12:10 PM
Default RE: Wheel alignment for 2001 monte ss
Hi Ricky,
We have several certified techs MCF Members, but
you may have to be patience to get the information
you requested.
I would suggest contacting a local wheel alignment shop
and see if they will share the information you need.
I dont think that information is in a Haynes Manual,
but many library have the Manuals. You can call and
ask them. Also you can call your local Chevy Dealer
Service Dept, or its better to stop in and sometimes
the tech's will print out the information for you.
Also Places like Midas Muffler has the information
in their computers.
I hope one of our expert members reads your post
and has the information you need.
Good Luck from
`Space
Old Aug 27, 2008 | 01:31 PM
montes my python's Avatar
these are for an 04 but should be close
WHEEL ALIGNMENT SPECIFICATIONS FRONT
FRONT SUSPENSION
CAMBER
Service Allowable -0.35 to -1.35°
Service Preferred -0.85° CASTER
Service Allowable 2.70 to 3.70°
Service Preferred Not Adjustable STEERING ANGLE
Service Allowable -3.50 to +3.50°
Service Preferred 0° TOE - TOTAL
Service Allowable -0.10 to +0.30°
Service Preferred 0.10° REAR SUSPENSION
CAMBER
Service Allowable -1.2 to +0.20°
Service Preferred -0.70° THRUST ANGLE
Service Allowable -0.15 to +0.15°
Feb 23, 2012 07:38 AM
robinma
May 25, 2010 06:50 AM
rickyk55
Aug 15, 2008 11:05 AM
RickCoMatic
Dec 31, 2007 09:32 AM
tj4ndirish
Aug 8, 2007 12:25 PM
