what up with my climate control
Old Jan 22, 2009 | 10:43 PM
victoryred05's Avatar
Default what up with my climate control
these mornings are cold and my monte takes very long for the heater to kick in and when it does it doesnt stay hot cool air starts to come out after about 1/2 hour of so. i have heard when i accelerate from a stop water swishing from under the dash are but thier are not any noticable leaks any suggestions its a 05 ls with 95k
Old Jan 22, 2009 | 10:44 PM
kweef's Avatar
Default RE: what up with my climate control
hmm there was a post like this once...wish out search engine worked. ill dig it up give me a few
Old Jan 22, 2009 | 10:50 PM
kweef's Avatar
k i couldnt find out post but check this one out http://www.gminsidenews.com/forums/f...shboard-71486/
sounds to me like u may have an air pocket and need to bleed out the air
Old Jan 23, 2009 | 08:18 PM
alrite ill try that thanks so much i did find similar post on this site about air bubbles i will be back if i run into how to do it
Old Jan 23, 2009 | 09:33 PM
RickCoMatic's Avatar
Your Coolant Level is probably very low. Remove the Radiator Cap when the Engine is Cold. Fill-up the Radiator with Coolant. Leave the Radiator Cap OFF. Turn ON the Heat FULL. Let the car Run. Be prepared to add Coolant as the Car heats-up. Keep the level of the coolant over the TOP of the Radiator Core. It will drop as the System purges itself of AIR. When the Thermostat Opens ... the Coolant will circulate pushing the Air in the System along to where it will escape at the Open Radiator Fill with cap OFF. Keep adding Coolant until alll the AIR is BURPED-OUT of the System. Have assistant increase RPM's to 2,000 and hold. Coolant will circulate rapidly. All Air will escape through OPEN Radiator Cap. Keep adding Coolant until NO more Air Burps-out. With RPM,s at 2,000 ... Fill Radiator until Coolant overflows from Radiator Fill into Overflow Tube. Seal Radiator Fill with Radiator Cap. Fill and bleed Overflow line to Overflow tank. Fill Overflow Tank to Level "Full Hot" ... Mark Full Level with Magic Marker for immediate visual reference. Keep overflow tank filled to Marked Level. Inspect for leaks.
Absent leaks ... your burning-up coolant. Have the System "Pressure Tested"
Crisby
Nov 16, 2008 07:13 AM
nitehwk10
Aug 19, 2008 04:23 PM
Anothermonte
Dec 9, 2007 06:39 PM
InTheIROC
Aug 20, 2006 07:18 PM
jcoeracing97
Aug 8, 2006 07:34 PM
