5th Gen ('95-'99): What engine parts are these?
Old Oct 9, 2016 | 01:08 PM
Sidestreet's Avatar
Default What engine parts are these?
Finally got curious enough to ask. I have some idea what these little items are, but it'll be good to know for sure:
Red arrow: No idea, really. It has three elements that look pretty much the same. My "wild guess" is the fuel pressure regulator.
Green arrow: Not sure. Vacuum line? EGR line?
Blue arrow: TPS (Throttle Position Sensor)?
Yellow arrow: line for the idle air bypass? (connecting to the intake elbow)
So... who knows their way around LQ1s?
File Type: jpg
Old Oct 9, 2016 | 02:11 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
Red is EGR Valve
Green Vacuum to upper plenum, cant recall exactly where from
Blue is Idle air control valve
Yellow is just a plastic vent tube, again can recall exactly from where
Its been a while since messing with 3.4 dohc
Old Oct 9, 2016 | 10:36 PM
I remember that EGR from the days of the early 3100's. On the 94/95 Grand Ams, they had issues with that thing popping codes. Sometimes you could simply clean up the carbon gunk build up and other times, not so lucky.
