6th Gen ('00-'05): Weather Strip for windows
The lower belt molding weatherstrip may be available here but here is the part# https://www.gmpartsdirect.com/oem-pa...strip-10317933
GmPartsGiant shows it as discontinued and they frequently are the only ones that have some parts. To my knowledge, there are no aftermarket manufacturers and probably won't be.
The upper reveal molding is still available but expensive and doesn't look easy to replace - I believe it is riveted on. https://www.gmpartsdirect.com/oem-pa...lding-10321351
You will likely have to troll the salvage yards for the belt molding.
Mod Guide: Sure Cure For Fluttering Seatbelts
Barovelli
FWD Tech Guides '95-'07
05-14-2010 10:01 PM
