6th Gen ('00-'05): Removing bottom part of seat (bottom seat cushion)
Old Nov 21, 2019 | 09:08 PM
N/A02NBMCSS's Avatar
Default Removing bottom part of seat (bottom seat cushion)
So my driver side ebony leather seats bottom is torn I went to the salvage yard today and found a leather seat with a torn top but good bottom I was wondering if it’s possible to remove the bottom cushion of the seat and put the nice one on my driver seat bottom since mine is bad
H E L P!
Old Nov 22, 2019 | 11:01 PM
Glen01SS's Avatar
Of course it's possible but you will need to unbolt the seat belt buckle from the seat frame. The seatback recline lever is held on by a small clip on the underside. The lumbar **** just pulls off. The cover panel has a screw on front and back. It is pushed into the frame in two places on either side of the recline, just carefully pry it out. The power switch is clipped into the cover panel. Then remove the lumbar cable screws from the panel.
The seat cover is clipped to the frame with white plastic clips. After you get the rear clip off, lean the seatback forward and you will find 2-5 hog rings under the rear flap - these hold the bottom cover and foam to the frame. Clip them or twist them off. The foam may be glued to the frame. The seat cover is velcroed to the foam. If either seat is heated, the harness is zip-tied to the spring assembly.
I haven't done an installation yet., just the junk teardown. (I found out I couldn't use the non-airbag seat in my car that has one.)
Old Nov 23, 2019 | 04:25 PM
All right thank you for the helpful info I will have to see if I can get it out!
Glen01SS
Jul 6, 2019 04:43 PM
barts
Aug 26, 2018 02:11 PM
MonteMan92
Feb 10, 2015 06:23 PM
Zeke
May 28, 2012 09:09 PM
24_48Fan
Aug 28, 2010 11:48 AM
