Water Pump Bolts
Old Jul 9, 2020 | 08:31 PM
WolvenScout's Avatar
Default Water Pump Bolts
I bought a Meziere electric water pump and it said it came with new hardware. But sadly, there isn't any in the box. I know the factory bolts are torque to yield, and need to be replaced. But I cant find any replacements for the 3800 engine, only the 3400. Does anyone know the two different sizes of the bolts for the 3800 water pump?
Old Jul 9, 2020 | 09:49 PM
Are they actually torque to yield? Never looked in the manual TBH and I've honestly never seen anyone replace them on a 3800. I know the install procedure is torque angle, just had never heard they were TTYs also.
I've got bolt sizes from back when I was planning to replace a bunch of bolts with nicer versions. Take it with a grain of salt of course, and I'd certainly bring your old ones to compare if you didnt chuck them:
Short = 1/4-20 × 1 1/8"
Long = 5/16-18 x 3"
Old Jul 9, 2020 | 09:56 PM
Long = 5/16-18 x 3"
Ah, I must have mistaken the torque angle spec to mean TTY. My bad.
I've seen people say the longer bolts are 25 ft lbs plus 80*, but my service manual doesn't say anything about an extra 80*, just the 25 ft lbs for the long bolts, and 16 ft lbs for the shorter ones.
Old Jul 9, 2020 | 11:13 PM
Not uncommon honestly. Since the vast majority of TTY bolts are spec'd with torque angle, many people get them interchanged. It is possible (although uncommon) to have a TTY bolt specified with a straight torque value, or to have normal bolts spec'd with a torque angle within their elastic range. The manual should specifically call out bolts that are one time use / TTY though.
Unfortunately I dont have my manuals unpacked yet from the move, otherwise I'd check what I've got too. That kinda stuff drives me nuts though- when you end up with different info for the same thing. I do recall having one manual (maybe it was the cheap Autozone book?) that called out a single spec for 'water pump', even though there are clearly two different sizes of bolts.
Old Jul 10, 2020 | 11:30 PM
Alright, I got the Meziere pump installed with new grade 8 bolts. I can confirm that the bolt info you provided is correct. I only torqued the four larger bolts to 25 ft lbs, so I'll definitely check to make sure they don't leak when I fill the system tomorrow. I also wanted to throw in some pictures.
Stock 3800 water pump vs. Meziere HD water pump
I definitely wont have any issues cooling the engine in the Texas heat with this thick of a radiator
Speaking of Texas heat, I had to go out and buy a canopy and box fan to even survive installing this water pump.
Old Jul 11, 2020 | 03:37 PM
That is a pretty radiator.
ChibiBlackSheep
FWD Tech Guides '95-'07
19
May 29, 2020 01:53 PM
fiveirontimmy
Jul 11, 2015 04:18 PM
shynativegrl
Jul 4, 2011 11:30 AM
Rich
Apr 13, 2010 11:36 AM
Phenomenon
Sep 3, 2008 10:43 PM
