Water in my passenger door
Old Oct 19, 2019 | 12:40 PM
Herman Munster's Avatar
Default Water in my passenger door
I had a door trim piece go missing and noticed my door was getting water into it I could hear it sloshing around . So I went to a wrecking yard and got another trim piece I made sure it was all sealed up . It's been raining here a lot lately and I'm hearing water in my door still and can not figure out how the water is getting in ? Any ideas ? Herman
Old Oct 19, 2019 | 10:39 PM
Jeffs02rwdSS's Avatar
Is it possible the water is getting past the outer window seal at the bottom of the window ?
Old Oct 20, 2019 | 02:15 AM
xpage's Avatar
there is a small hole near the end of the door (not by the hinge side). It is probably clogged and preventing water from going out. Hence the sloshing. Happened to me. A toothpick, or small screwdriver will get rid of the gunk and allow the water to drain.
Old Oct 20, 2019 | 10:53 AM
It all looks good rubbers seals just LIKE WHAT ???
Old Oct 20, 2019 | 11:01 AM
Well I didn't know there is a drain hole I will have a look at the door today. I was going to drill a hole myself .I'm just waiting on new door speakers so want to get this problem solved before I put new speakers in (mind you there water proof but still water in your door can't be good .) Herman
Hatchett3994
Apr 7, 2015 06:52 AM
Zeke
Apr 14, 2012 06:58 PM
sevnfoe
Dec 3, 2010 09:41 AM
Boxman420
Aug 3, 2010 10:53 PM
dupree155
Mar 21, 2010 09:23 PM
