Water Leaking on Passenger Side AND No Sound from Speakers
First off, new to the site great forum!
Now, recently I am having so many problems with my poor MC
I don't know what the problem is, it happens randomly. Ill get in the car and the passenger side floor is wet. It seems like it might be running down from the dashboard.
Also my sound just stopped working too! It's not the radio cause even when the gas light came up- NO SOUND. I haven't tried a new amp yet, but I tried to take off the dash to see if there was any problem behind back there, and what do you know..more problems. I can't get the bottom left latch underneath the Heat/AC controls to click back in and the ignition trim or faceplate (whatever you wanna call it) won't go back in because it must have been broke and glued on by the people I got the car from.I looked on eBay and $25 dollars for one seems like way too much.
Anyone with any help/advice it is greatly appreciated and needed haha
Your water on the floor is a common issue and very easy to fix
Just change your cabin air filter. There's a piece of weather stripping that likes to come loose and by changing the filter, you'll fix it.
7th Gen ('06-'07): Need some help with water leaking on passenger side of 7th Gen Monte. Please help!
MCSS06
May 29, 2015 08:04 AM
