Water Leaking Into Passenger Cabin
Old Oct 29, 2011 | 11:34 PM
Vladimir's Avatar
Default Water Leaking Into Passenger Cabin
So I had this problem very serious several years ago. Finally a mechanic fixed it, said it was something plugged I think? Only obviously a problem when it rains. It comes from under the dash, about the middle I think. Hard to tell it must be a small leak doesn't leave much of a trail but fills the passenger floor with a good couple inches of water. I have pulled the carpet up and have it propped up to try and dry out (never did that before looks kinda gross under there!). I'd rather not take it to a mechanic since it took about four trips for them to fix it (was always a "Oh while its here please look at this...").
I want to also get it in the garage next week with some fans, I assume the only way to keep the lights off with doors open is to disconnect the battery?
Also there used to be a sweet site I would use with the diagrams of all the sections of the monte carlo and you could pick the parts and get part numbers to buy online. Where is that, can't seem to find it?
THANKS!
Old Oct 30, 2011 | 12:23 AM
oneslowmonte's Avatar
There is a write up on it, I'll try to find the link, it ends up being a fairly simple and extremely inexpensive fix
Edit: Here you go! https://montecarloforum.com/forum/si...lem-fix-26663/
MCSS06
May 29, 2015 08:04 AM
Cowboy6622
15
Dec 29, 2012 09:28 PM
monte07
Sep 14, 2011 09:19 PM
LonelyStoner
Jul 22, 2010 02:07 AM
Brooke
Oct 17, 2007 04:35 PM
