Water gurgling noise in the dash
Old Jan 14, 2014 | 02:17 PM
cali2000ss's Avatar
Default Water gurgling noise in the dash
When I start my 2000 Monte Carlo SS 3.8 It make a water gurgling noise from the dash. I could use some help figuring out what is causing the problem...
Old Jan 14, 2014 | 02:51 PM
Im guessing your ac evap tube is clogged....
When you run your ac is there any moisture showing up on the ground?
Old Jan 14, 2014 | 04:45 PM
cali2000ss's Avatar
My ac don't work it doesn't get cold...
Old Jan 17, 2014 | 04:42 PM
bowtiebandit23's Avatar
where is the evap tube? every now and then i get the same issue. had it on all of my vehicles but ac still blows cold and yes in park with it on it will drip water.
Old Jan 17, 2014 | 09:17 PM
A05C's Avatar
That noise is caused by the heater core. Check around for a coolant leak and make sure there is no air in the cooling system.
The fluid level gets low and the heater core can't fill up causing that noise.
Old Jan 29, 2014 | 09:25 PM
Bustacapp's Avatar
Default check the plastic elbows
there are two plastic elbows that go from the radiator to the engine/intake that crack when they get old and brittle you may get lucky and that is all it is they're like a 20$ part and take a hour or so to replace
monte ls
Mar 25, 2014 08:06 PM
ltman
Nov 28, 2008 06:35 PM
ltman
Apr 11, 2008 05:48 PM
Brooke
Oct 17, 2007 04:35 PM
marctapp
Jun 28, 2007 02:27 PM
