Gurgling noises
Old Mar 21, 2014 | 09:44 AM
monte ls's Avatar
Unhappy Gurgling noises
So whenever i tend to take off from a stop sign or red light , my car makes a gurgling noise and i dont what it could be , it sounds like its coming from the back right under the hood if your sitting in the car . Also realized my heat doesnt work that well unless im giving it gas . Any ideas what it could be
Old Mar 21, 2014 | 10:02 AM
More than likely your low on coolant... for the no heat issue...
also you may need to bleed the air out of the system..it may just have a vapor lock (air pocket)
The gurgleing could be as simple as the AC condenser drain is plugged... Take a cloths hanger and poke it in the drain tube and see if that doesn't let the water out...(as deep as it will go inside) It just maybe built up condensation from running your AC through out the year..
It may also have the T Stat stuck open..which means you may need a new T Stat.
Old Mar 21, 2014 | 10:37 AM
monte ls's Avatar
Thank you!
Old Mar 21, 2014 | 10:40 AM
Originally Posted by monte ls
Thank you!
Your quite Welcome!
Were here to help!
Old Mar 21, 2014 | 10:54 AM
monte ls's Avatar
This might sound like a dumb question but where exactly is the condensor drain located ? I dont want to poke through the wrong thing
Old Mar 21, 2014 | 11:22 AM
Its just off the firewall at the back of the motor...(below/around the heater box)
It may also appear as a an elbow coming out of the firewall... You may just be able to remove it and allow the water to drain out... (I'm not exactly sure without seeing yours)... Bu it should be easy to find from underneath it.
After some thought...
I'm almost sure your T stat is in the stuck open position..since you said you only get heat when your driving it.
Old Mar 21, 2014 | 01:53 PM
nitehawkjcb's Avatar
Bleed/fill your cooling system. That's likely the issue.
If that doesn't fix it, if you have a sunroof, I've heard of those drains getting clogged and pooling water inside the passenger door.
Old Mar 21, 2014 | 04:33 PM
monte ls's Avatar
I checked my coolant and it was low so i put some in, and i still have the noise and im having a hard time finding the plug to drain the water out, please help ��
Old Mar 21, 2014 | 04:39 PM
Theres no "Plug"....
Its a hose...
Ever notice when you run your AC... Theres generally a puddle under the car on the passenger side of the vehicle...
That's the hose your looking for... to unplug to drain out the excess water from the evaporator...
What year is your Monte Carlo?
Old Mar 21, 2014 | 04:57 PM
monte ls's Avatar
2003 . I looked it up a little more and they said there was a 90degree plug comong off the firewall and if i unplugged it, water would come out there for resolving the problem, well i just went under my car and did that and nothing happened. What hose am i looking for. And sorry for not getting it the first time around
