Vacume leaks?!?!?
Old Apr 15, 2009 | 01:57 AM
Weber's Monte's Avatar
Default Vacume leaks?!?!?
I'm trying to find a vacume leak in my 06 MC with the 3.5 v6 in it and is there anywhere that they are noteorious for vacume leaks? I can hear a whistle once and a while.
Old Apr 15, 2009 | 07:14 AM
sonin66's Avatar
i think you and me have the same problem(i have a 3.9). are you leaking coolant? or see oil mixing with your coolant?
Old Apr 20, 2009 | 12:21 AM
Im not shure i'll check what's wrong with your mc that oil and coolant is mixing? I havent really looked at my coolent short of looking at the reservoir to see if coolent was in there and when i check my oil i dont see signs of coolent but I will check tomarow and get back to you.
Old Apr 30, 2009 | 01:37 PM
slone56's Avatar
When you hear the whistling, have the engine running and spray all vacuum lines, intake flanges, power brake booster and anything that uses vacuum with starting fluid. It will get sucked in at the leak and change the RPM's Don't worry, it evaporates fast, you will never know you even sprayed it on your stuff.
wilradackal
May 1, 2010 08:41 PM
nascar43
Sep 1, 2009 07:59 AM
DebbieJ
Oct 5, 2007 06:54 PM
DebbieJ
Oct 1, 2007 12:05 AM
chasedcash
Oct 6, 2005 10:01 AM
